Turbos on my mind. - Road Glide Forums
 12Likes
post #1 of 51 (permalink) Old 03-28-2016, 12:33 PM Thread Starter
BigNorm's Avatar
Turbos on my mind.
Does forced induction appeal to anyone else? I have been looking at different "kits" and RB Racing's appeals to me the most. Having a huge turbo seems to make the most sense to produce the most amount of boost possible at the low rpms our Harley motors run. The huge intercooler makes sense too. Why would you hamper the flow? The thing that is not so fun about turbos is the cost which makes it cost preventative for me at this time which means let's talk about them and learn as much as we possibly can. I like the idea of running 9:1 compression with the ability to get up to 250 horse power or more. Is it necessary? Don't be silly, of course it is!
Is there a spot off the motor that will feed the turbo's bearings? The sending unit it the only spot I can think of. Would one of the plugs from the motor provide pressurized oil?. How about a place for oil to return to the motor?
Tuning this type of system appeals to me as well. Can it all be done off of two injectors or would secondary injectors be a better idea. Are there tools in the tuners that increase the amount of fuel corresponding to boost or is this something that has to be figured out cell by cell? There is a lot of this that appeals to me. I'm not sure if I'll ever be able to put all the pieces together but it sure would be cool to get the chance. Take care and I hope I'm not the only one this appeals to.
BigNorm is offline
post #2 of 51 (permalink) Old 03-28-2016, 09:42 PM
MightyWhitey's Avatar
Let me start by saying that I am no expert. That said I do drive a turbo Subaru, WRX, so yes boosting appeals to me as cars go. Bikes, not so much. I'd rather have torque in large numbers off the bottom rather than at higher rpm. We are talking about heavy antiquated equipment here. Don't forget you're going to have to stop it. Possibly in a hurry. Wouldn't a 124" be more useful? Correct me if I'm wrong but 9:1 static CR + even a measly 3-4lbs boost is going to creat an effective CR of over 12:1 and is going to require race fuel of a high quality. I really don't think that amount of boost is going to creat the numbers you're hoping for. Don't shoot the messenger!!! I'm not trying to piss on your parade just playing devils advocate here and giving you some things to consider. And hey, I might be wrong too. It has happened before...I think...maybe, I really can't remember. Okay I'm going to get my vest on now. 😃
BigNorm likes this.
MightyWhitey is offline
post #3 of 51 (permalink) Old 03-29-2016, 12:19 AM
JacktheBagger's Avatar
Ya start with low compression pistons , like 6.0 to 1 t o compensate for the boost .. RB does some good stuff , they have some good videos of their blown Roadie with all their goodies on the dash , they did some stuff for me many years ago ..
On the one hand turbos are the ultimate aw s^&% for cool , but in the end , I think I'd opt for more cubes ..
BigNorm likes this.
2011 Ultra
JacktheBagger is offline
post #4 of 51 (permalink) Old 03-29-2016, 05:49 AM
Forced injunction is a blast.
Turbos are fun. But a very big turbo makes more top end power and less bottom end. I have found over many years of building blower/turbo bikes up to 600 hp the smaller turbos work great for Harleys if peak number are not an interest..
We just built over the winter 7 turbo build and ran 22 mm turbos
3 of them were 107 making at 8/9 boost 155/180 hp. To much boost to fast on HD,s is not the best thing you start blowing head gasket and could lift studs. If we run bigger turbos
Like 25/ mm or 28 mm we will change the motor design to make a progressive curve. I built 124 turbo engine for my 2015 RG waiting on Aero charger they are sending me a 66 series system for me to test and run should be according to the math 245/263 hp. Can't wait! Should be here I hope in mid April.
If you have questions just me a shout.
Thanks FD
BigNorm and Keg69 like this.
DragoBikeWorks is offline
post #5 of 51 (permalink) Old 03-29-2016, 06:55 AM
Just finished our 2nd 117" turbo build this season, in between the all-motor 117"s and 124" builds.
Heat cycles were performed yesterday.
1st was built with a Fueling .575, our Stage IV Heads, 66mm S&S T/Hog and an Aero, and the 2nd, now, has a Wood 777 with a Trask unit, our Stage IV Heads, 66mm S&S T/Hog.
Both 2015 RG's.
The Trask has a hellava whistle to it.
The Aero tuned off to HUGE power, and was on the edge of needing a larger turbo as both were 103"ers, already equipped.
Scott
Hillsidecycle.com is offline
post #6 of 51 (permalink) Old 03-29-2016, 08:03 AM Thread Starter
BigNorm's Avatar
How much attention needs to be paid to the bottom end? Upgrading the crank and doing the Timken bearing are on my list next. I like the look of the Trask system but wonder if the intercooler is big enough. I would be looking towards the next level of fun factor in doing this. I was looking up old posts on HTT yesterday reading all I can on the topic. Does the kit come with a new intake? I was just thinking of the vacuum hose on the stock intake. I imagine that would pop off quick if boost was added. I like that turbos aren't full time boost as much as I think a supercharger would be. I'd like the best of lower compression longevity and The power to get on it when I wanted. Does TTS Mastertune have tools for forced induction?
I'd like to thank the big boys for chiming in. The idea of starting this post was to provide a spot to ask all your turbo questions for community discussion. I want to know as much as I can about this before I pull the trigger.
BigNorm is offline
post #7 of 51 (permalink) Old 03-29-2016, 08:05 AM Thread Starter
BigNorm's Avatar
How do the stock head studs fair under boost? What is the best head gasket to seal the power?
BigNorm is offline
post #8 of 51 (permalink) Old 03-29-2016, 08:37 AM
The systems do not come with intakes.
The crank is very important when going with forced induction.
Forge crank is best reworked right should handle big power. My favorite crank is from P3R ply wheels. Dave builds them custom specs for install.
The standard TTS is not set up for boost with 2 bar map sensor.
Steve and I have talked about this and he has been working on one for boosted bikes in his spare time. For now we use the thunder max with 2/3 bar map sensor. It has all the controls to tune in boosted bikes with its own software and timing and fuel trims under boost. The inter coolers on most systems are to small. Trask has made a bigger one for the 25/28mm but in my OP still little on the small side. When we get into our setups we can build bigger inter coolers that can flow 800 cfm of air for the turbos. I have been building boosted bikes for very long time. And have been down the road on what does not work so I will design and build what we need. We offer full line of custom blower/ turbo parts from pistons,cams etc., injectors and so is on.
QUOTE=BigNorm;3279977]How much attention needs to be paid to the bottom end? Upgrading the crank and doing the Timken bearing are on my list next. I like the look of the Trask system but wonder if the intercooler is big enough. I would be looking towards the next level of fun factor in doing this. I was looking up old posts on HTT yesterday reading all I can on the topic. Does the kit come with a new intake? I was just thinking of the vacuum hose on the stock intake. I imagine that would pop off quick if boost was added. I like that turbos aren't full time boost as much as I think a supercharger would be. I'd like the best of lower compression longevity and The power to get on it when I wanted. Does TTS Mastertune have tools for forced induction?
I'd like to thank the big boys for chiming in. The idea of starting this post was to provide a spot to ask all your turbo questions for community discussion. I want to know as much as I can about this before I pull the trigger.[/QUOTE]
BigNorm likes this.
post #9 of 51 (permalink) Old 03-29-2016, 09:13 AM Thread Starter
BigNorm's Avatar
Thanks Frank. I know it seems silly but how is the vacuum hose addressed? Hose clamp? Is there an additional sensor installed that measures boost? I didn't know that you built your own systems so I am very interested in that. I have a PCV right now and have heard it can work with boost or maybe it needs an autotuner to work. I'm learning as I type and am very thankful for all the help I have received.
Desertwndrr likes this.
BigNorm is offline
post #10 of 51 (permalink) Old 03-30-2016, 06:20 AM
BlownBagger's Avatar
Both 2015 RG's.
Scott
Scott I would be interested in seeing the Dyno sheet from this build once your finished tuning it.You often talk of these builds but never post a dyno sheet.I would think after being in business 30yrs. you would be able to post at least one dyno sheet from all of your many builds.
_
BlownBagger is offline
So ive made up my mind or should i say 95% of my mind........ maddmoe *General Road Glide Discussions/Pictures 12 08-29-2014 02:48 PM
RB Racing Intercooled Harley Turbos DreamRider Engine Related 20 01-12-2012 05:24 PM
Can't make up my mind... anyone got pictures.. SafetyMan *General Road Glide Discussions/Pictures 10 10-27-2010 06:43 PM
Changed my Mind Towerhog Road Glide Specific Discussions 20 10-17-2010 09:42 PM
Changd my mind! Peewee Controls & Handlebars 9 07-30-2010 02:14 PM
