S&S premium adjustment - Road Glide Forums
post #1 of 23 (permalink) Old 04-03-2016, 08:53 AM Thread Starter
BigNorm's Avatar
After playing with my crane cams lifters and learning all kinds of different valve train noises I am considering getting the S&S premiums. I have SE adjustable pushrods. how many turns down will make the premiums work? After playing with Chevy 350 lifters I can say I shouldn't have tried to cheap out on the lifters. Just a poor white boy in a cruel world trying to save a buck. Thanks for the help. NORM
BigNorm is offline
post #2 of 23 (permalink) Old 04-03-2016, 09:26 AM
Bruckus's Avatar
I believe with the Harley adjustables it is 4 full turns. If you get the S&S with limiters you do the same but after bleed down you then shorten 1 full turn. I'm sure some of the more qualified engine guys will chime in.
2013 Roadglide Custom - Candy Orange
Drago's Dragula True Duals, Thundermax Tuner
Daymaker LED Headlights, Supershox
Bruckus is offline
post #3 of 23 (permalink) Old 04-03-2016, 09:30 AM
Smarty's Avatar
Norm, you don't need to buy the premiums. The standards are quiet as a mouse. Are you sure you are chasing lifter noise?
midwaywfo likes this.
2016 RGS Black Quartz
Smarty is offline
post #4 of 23 (permalink) Old 04-03-2016, 09:47 AM
Road dawg's Avatar
My SE pushrods non-taperd type said in the paper work 2.5 turns but I got some noise, called S&S they told me turn to 3.25 to 3.50 adjustment I did and all noise was gone, good luck.
Road dawg is offline
post #5 of 23 (permalink) Old 04-03-2016, 10:06 AM Thread Starter
BigNorm's Avatar
I'm pretty sure. I've learned that with these lifters they bottom out at 3 turns and a flat. I had them down tight. A friend of mine who is a Harley tech told me to loosen them up a flat or two because it was making valve spring noise. That being said. I readjusted the whole thing again at 1 1/2 turns down or 6 flats. Now the lifters themselves are making the noise. It kind of reminds me of the noise I had when I ran roller rockers on a Boss 302 I built way back when AND there is still a slight tic but I think it's coming from the lifter. I'm thinking of taking all the heat shields off my pipes to make sure that's not the issue. I wish I could have my pipes ceramic coated. I'm not sure if that can be done once the pipes have been used I love the Rhinehart pipes and muffler performance wise but the damn heat shields always seem to rattle.
I thought if I bought premiums now it would help me in the future if I continued playing with the motor which is extremely likely now that I've had my first taste of Harley performance. I love the 57H cam. I need to set my rev extender on my PCV. The motor breaths and pulls hard and wants to go past the 5k rpm redline. Power in is instantaneous from 3000 on up. Anywho. The valve train is a lot quieter with these lifters set at 6 flats. I'll ride it until I can spring for the premiums. Who knows. I may be running a turbo next. lol.
BigNorm is offline
post #6 of 23 (permalink) Old 04-03-2016, 10:29 AM
Smarty's Avatar
There is no adj. pushrods made that are only 1 1/2 turns for adjustment. Look up your pushrods and see how many threads per inch. You want your lifters set at approximately 1/2 depth of the lifter (distance from bottomed out to fully up on the cup. I sometimes because of the ramps on the cam I'm using go another 1/2 turn in to quieten them down.
Smarty is offline
post #7 of 23 (permalink) Old 04-03-2016, 10:52 AM
Road dawg's Avatar
+1 on that for sure.
post #8 of 23 (permalink) Old 04-03-2016, 11:08 AM Thread Starter
BigNorm's Avatar
I'm glad my thinking was strait then. When I figured that bottomed out was 3 turns one flat my thought was to cut the distance in half. I'll add this one to experience. I may give Larry's a try. I like that he has a groove machined in to lube the pin. Larry's motorcycle machine
BigNorm is offline
post #9 of 23 (permalink) Old 04-03-2016, 11:10 AM
lil chief's Avatar
Are you sure it's valve train noise you're hearing & not reversion from your 57H cam? Plenty of posts about that cam causing reversion noises.
SE pushrods are generally 24tpi. I believe the instructions call for 2.5 turns from zero lash. Like Smarty sez, get em set half way down into the lifter, which is usually around .100". You can go a little deeper possibly, but find that sweet spot.
I ran a set of AMS Johnson Hylift lifters in my old bike & I initially set the rods at 3 turns from zero. Those lifters didn't like that & were bottoming out. I backed off the rods to 2.5 & all was nice & quiet.
Lil Chief
lil chief is offline
post #10 of 23 (permalink) Old 04-03-2016, 11:32 AM Thread Starter
BigNorm's Avatar
I'll give these one more shot I guess but I can already feel a new set of lifters burning a hole in my pocket.
BigNorm is offline
Hd Premium Shock adjustment ChromeYellow67 *General Road Glide Discussions/Pictures 8 01-16-2015 03:57 PM
Amp gains and final adjustment advice needed vinman4444 Audio 5 04-29-2014 07:13 AM
New 500W Amp Gain Adjustment gpdstaffcapt J&M 2 02-15-2013 09:01 PM
RF amp install and headlight adjustment Mcrider996 Lighting 1 04-26-2012 02:00 PM
I’m giving away Premium Chrome Tour-Pak Hinges & Latches if you help me Cmathias General Off-Topic Discussions 54 02-02-2012 06:27 PM
