Rocker locker - Road Glide Forums
 4Likes
post #1 of 24 (permalink) Old 04-04-2016, 01:22 PM Thread Starter
SMOKENJOE's Avatar
Rocker locker
Anybody used the locker rocker and do they work thanks
SMOKENJOE is offline
post #2 of 24 (permalink) Old 04-04-2016, 02:08 PM
I have not used them and I don't know anyone personally that has, but I've read nothing but positive things about them. I plan on putting them in the first time I have the rocker covers off...
2015 RGS, Performance Machine Max HP A/C, Chrome Dragula II, Dyno tuned by Ed @ The Dyno Difference in Dallas, TX, Klockwerks 14" Sport Flare.
padwell88 is offline
post #3 of 24 (permalink) Old 04-04-2016, 02:18 PM
tdkkart's Avatar
I have them installed. Do they take away all the valvetrain noise?? No.
Do they take away the noise in the 2500-3500rpm range that has plagued nearly every twin cam since their inception??
Yes.
They do work to take away the portion of the noise that is caused by the rocker shafts.
tdkkart is offline
post #4 of 24 (permalink) Old 04-04-2016, 02:55 PM
Is the same thing as Rockout or is it a different approach to the same problem?
2013 Road Glide Ultra, Rhinehart exhaust, Stage IV kit and more.
mstreak1 is offline
post #5 of 24 (permalink) Old 04-04-2016, 03:09 PM
tdkkart's Avatar
Same-same
tdkkart is offline
post #6 of 24 (permalink) Old 04-05-2016, 08:24 AM
If the rocker arms have back and forth movement and witness marks, good idea to install them. Most are not loose, so expecting the "lockers" to remove other noises such as lifter, heavy valve springs/seat pressure, or TB plate noise will disappoint.
rg113 is offline
post #7 of 24 (permalink) Old 04-05-2016, 08:49 AM
Smarty's Avatar
Same here, know several who have installed them with good success. It does take away that dreaded 2800-3200 noise you hear coming from your your fairing area. On bikes without fairing, no-one ever hears this noise.
2016 RGS Black Quartz
Smarty is offline
post #8 of 24 (permalink) Old 04-11-2016, 01:16 PM
i installed the rouckouts (which are similar to rocker locker) and they def quieted things down considerably. there still is a tiny bit of valvetrain noise but it's an engine. i'd say the valvetrain noise was reduced an easy 80% and to me was definitely worth it. you mileage may vary.
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
post #9 of 24 (permalink) Old 04-11-2016, 01:37 PM
skratch's Avatar
i installed rockouts on my cvo 110. while i didn't think that it was bad to start with, it was substantially quieter afterward. noise is reduced significantly. and in my case, not just in the 2800-3200 rpm range. definitely worth the $15
skratch is offline
post #10 of 24 (permalink) Old 04-12-2016, 06:22 AM
Used 'em.
They help.
A set screw drilled/tapped into the support plate, locking the shaft, works also.
Scott
Swomack likes this.
Hillsidecycle.com is offline
Installed Chrome bolts in the Rocker Covers ironmark *General Road Glide Discussions/Pictures 9 04-05-2012 12:19 AM
Gloss Black HD Detachable Sissy Bar/Rocker Box Covers/Cam Cover Bigdaddymike Classifieds Archive (3 months old+) 7 01-26-2012 05:27 PM
Goat Locker Gang Social Group JacktheBagger Active Military and Veteran's group 29 10-30-2011 09:23 PM
rocker switches ozbowhunter *General Road Glide Discussions/Pictures 5 04-27-2011 09:10 AM
Front rocker cover removal? racerdave Troubleshooting for Road Glides 1 03-23-2011 02:25 PM
