Does a new cam change your RPM - Road Glide Forums
 2Likes
  • 2 Post By mocotom
post #1 of 8 (permalink) Old 04-04-2016, 04:41 PM Thread Starter
Brianu1's Avatar
I put a TW-777 cam in last fall, and I can't quite remember, but if memory serves me, when I used to run about 75mph in 6th gear I was pulling around 3000rpm. Yesterday I was out for a putt putt, and now I am running about 80mph at 3000rpm. The bike seems to want to run a little less rpm vs the same speed the other cam did. Does that make sense? That also then would be better MPG, correct? If I cam pulling less rpm at the same speed?
Sorry, not much of an engine aficionado.
Thanks.
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 8 (permalink) Old 04-04-2016, 04:52 PM
mocotom's Avatar
Thanks.
A cam will not change the rpm to speed ratio, only changing the gearing can do that.
'05Train and Smarty like this.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 8 (permalink) Old 04-04-2016, 05:15 PM
Sounds like a tail wind.
post #4 of 8 (permalink) Old 04-04-2016, 06:49 PM
Question
Tail Wind!!!!! ha ha ha ha ha!!!! Like that one.
nanook is offline
post #5 of 8 (permalink) Old 04-04-2016, 08:02 PM
Yep, nothing like a magical Wood cam.......now that should start something........I'm outta here !!!
G5Driver is offline
post #6 of 8 (permalink) Old 04-05-2016, 11:33 AM
The speed vs rpm remains the same. The rpm vs torque will change.
post #7 of 8 (permalink) Old 04-06-2016, 12:35 AM
IdahoHacker's Avatar
Unless your mechanic changed either the transmission, primary drive pulley, or the rear wheel pulley, and I'm guessing he didn't do any of that, then, no, that's not possible.
2015 FLTRXS, SE Ventilator A/C, V&H Pro Pipe, S&S/Crane Chris Rivas Rocket 574 cams, Chris Rivas V-Twin dyno tune: 103 hp, 108 tq.
IdahoHacker is offline
post #8 of 8 (permalink) Old 04-06-2016, 07:21 AM
RGKen's Avatar
Thanks.
I think you may be remembering it wrong. 80mph is what I cruise at on the interstate and every bike I have had ran at 3000rpm (maybe a little over) at that speed in 6th gear. That was with 96", 110", and my current 120". Of course I could be wrong too so I will double check the next time I go out.
2018 FLTRXS
RGKen is offline
'18 header and exhaust change - does it void the HD warranty? Sharkbreath Intake and Exhaust 20 09-16-2018 04:42 PM
Lifters: to change or not to change BigNorm Engine Related 14 01-19-2016 08:50 AM
ow to change the speedo and rpm gauge lights?changing Mr.Goodtime Lighting 44 06-13-2013 01:06 PM
How many forum members does it take to change a lightbulb? RGCBandit General Off-Topic Discussions 27 10-15-2012 08:21 AM
How long does it take to change a stator? ironmark *General Road Glide Discussions/Pictures 10 01-31-2012 10:27 PM
