Signs of a slipping crank - Road Glide Forums
 2Likes
  • 1 Post By Hillsidecycle.com
  • 1 Post By HellInABucket
post #1 of 10 (permalink) Old 04-07-2016, 02:28 AM Thread Starter
Went from a decatted stock head pipe, slip ons, a SE air cleaner, and a PCV. To a fuel moto 2-1-2 headpipe and a powervision. Noticed after the install and its maiden voyage I have more vibes when letting off throttle and higher RPM applications. Would yall say this is a result of the new harmonics of the new headpipe or do you think there is a possibility my crank has slipped with just 3500 miles? Bike is rode hard I take care of it but when I ride I do ride it pretty aggressively.
shrekmoose is offline
post #2 of 10 (permalink) Old 04-07-2016, 05:50 AM
'05Train's Avatar
I'm a very aggressive downshifter and engine-braker, and I've never slipped a crank. It's very unlikely that's your issue.
'05Train is offline
post #3 of 10 (permalink) Old 04-07-2016, 06:21 AM
A dyno tune would probably cure it.
Doubt that your crank has sissored.
Scott
Keg69 likes this.
Hillsidecycle.com is offline
post #4 of 10 (permalink) Old 04-07-2016, 06:36 AM
HellInABucket's Avatar
I doubt its your crank. I'd look at the head pipe installation - is it rubbing anything? Look for possible contact points, etc.
kouack likes this.
HellInABucket is online now
post #5 of 10 (permalink) Old 04-07-2016, 07:48 AM
Smarty's Avatar
As above said, I had the same thing and it was the D&D header pipe rubbing the right footboard after cranking. With the engine cutoff, it was close but not touching. Check these things and it should be the problem.
2016 RGS Black Quartz
Smarty is offline
post #6 of 10 (permalink) Old 04-08-2016, 01:25 AM Thread Starter
thats what im figuring too. didnt notice it touching anything but good idea may be touching with it running. Its not extreme vibration like a buzzy feeling that makes your feet go numb and mainly in upper revs past 3.5k to 4k when it starts. Thinking it also may just be the different pipe may have changed the tone a little and im feeling more of it now.
post #7 of 10 (permalink) Old 04-08-2016, 08:52 AM
lil chief's Avatar
One other possibility is a lean condition in that rpm range. I lean condition can cause vibration.
Lil Chief
lil chief is offline
post #8 of 10 (permalink) Old 04-08-2016, 07:47 PM
Try loosening the clamp bolts at the slip on, head pipe junction and loosen the muffler bracket bolts at the rear of the mufflers. Start the bike, let is idle a couple minutes, shut off engine and retighten the bolts.
grambo is offline
post #9 of 10 (permalink) Old 04-08-2016, 08:48 PM
I would double check the installation before I would condemn the anything else. Make sure the pipes or anything is hitting a floorboard or something.
post #10 of 10 (permalink) Old 04-11-2016, 06:54 AM
The first sign of a fubared crank is actually lifter noise, as the pump is getting gyroed and causing air to be introduced into the oil.
Scott
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 09:03 AM
big crank or mega crank battery Onthehunt49 General Off-Topic Discussions 7 04-10-2016 06:27 PM
Stock crank vs. S&S crank HDBAGR Engine Related 11 05-23-2015 04:21 PM
Clutch Slipping? PhrogFlyer Troubleshooting for Road Glides 17 03-11-2013 06:12 PM
tranny slipping ES ROADGLIDE SJ Troubleshooting for Road Glides 0 04-22-2012 04:00 PM
