TW-222 Dyno results - Road Glide Forums
post #1 of 11 (permalink) Old 12-19-2012, 08:25 PM Thread Starter
Trex69's Avatar
TW-222 Dyno results
Got a Dyno tune on the Woods TW-222 cams i installed a couple of weeks ago,definately an improvment.
2012 FLTRX
V&H 2-1 Propipe V&H VO2 ,Woods TW-222 cams,PCV,Heritage Bars,PBR 300x2 Amp Focal 165 CVX speakers.
Trex69 is offline
post #2 of 11 (permalink) Old 12-19-2012, 08:47 PM
Harleyagain's Avatar
Very nice numbers! knowing what they where before the cam would of been interesting.
Bob
Harleyagain is offline
post #3 of 11 (permalink) Old 12-19-2012, 08:52 PM
Triplej's Avatar
Sweet and I hope my numbers are that good when I get around to installing those cams.
Harleyagain, maybe we can experiment on your bike first?
Triplej is offline
post #4 of 11 (permalink) Old 12-19-2012, 09:02 PM
Funny you should say that, I was thinking the same!
Bob
post #5 of 11 (permalink) Old 12-19-2012, 09:19 PM
INDEPENDENT 1
Guest
Posts: n/a
Something about your dyno sheet looks messed up. You have a higher max Torque number than HP number yet your HP line goes up further on the graph than your TQ curve does. Looks like the scaling is effed up.
post #6 of 11 (permalink) Old 12-19-2012, 09:30 PM Thread Starter
Trex69's Avatar
Hp scale on the left Torque scale on the right ......it is what it is
2012 FLTRX
Trex69 is offline
post #7 of 11 (permalink) Old 12-19-2012, 09:36 PM Thread Starter
Trex69's Avatar
I would think like most stock would be arround mid 60's HP and low 80's TQ
but every bike and every dyno is a little different
2012 FLTRX
Trex69 is offline
post #8 of 11 (permalink) Old 12-20-2012, 12:58 PM
jupiter's Avatar
yeah, the scaling is definitely off. The hp and torque curves should cross at about 5500 rpm but this looks different.
Nice peak numbers though!
Priscilla- 11 RGU VB with FM intake, HP, DT mufflers and FM tune.
jupiter is offline
post #9 of 11 (permalink) Old 12-20-2012, 02:52 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Great numbers! the scaling is not exactly normal however that only affects the way the chart is layed out. It does not change the actual numbers or curve.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #10 of 11 (permalink) Old 12-20-2012, 08:39 PM
RoadGlideGary's Avatar
Tw 222
Nice results. I'd like to see the results for this set up on a 96"
05' SuperGlideCustom - sold
RoadGlideGary is offline
Dyno results 103" TW-777 cams Brianu1 Dyno Results 20 03-14-2016 02:16 PM
*New* TW-222 cams by Wood Performance fuelmoto Fuel Moto 44 09-16-2013 11:46 AM
PC-V map for Woods TW-222 Cam Ghostrider Map Section 0 12-12-2012 09:15 PM
Woods tw-222 cams 07 and up twins pat123 Sold 6 12-05-2012 12:03 PM
96" motor Wood TW-222 cams fuelmoto Dyno Results 3 11-08-2012 09:45 PM
