Metal shards on primary plug?? - Road Glide Forums
 6Likes
post #1 of 20 (permalink) Old 05-05-2016, 05:44 PM Thread Starter
cookie114's Avatar
Noticed 2 pieces of metal about 1/2 in long on my primary drain pluggable servicing it. It had the normal junk on the plug but the 2 pieces of metal concerns me. Bike had formula + in it and ODO is at 11,800. What's the deal?
2013 FLTRX, stage 1 w/vance and hine power duals and rinehart slipons, TTS mastertune and some other odds and ins. Long ways to go
cookie114 is offline
post #2 of 20 (permalink) Old 05-05-2016, 09:28 PM Thread Starter
cookie114's Avatar
Anyone seen this before? Any suggestions or recommendations?
post #3 of 20 (permalink) Old 05-05-2016, 09:45 PM
The fuzz on the magnetic drain plug is normal. Those splinter pieces don't look like they should be there. The fuzz is from basically metal to metal surface contact such as compensator and clutch wear etc. The splinter pieces may be clutch material. Does it shift and run normal? Any work done to it recently? If you do your own work I'd dive in just to make sure everything is ok. If not then bring in into a shop for inspection
post #4 of 20 (permalink) Old 05-05-2016, 10:20 PM
r_einan's Avatar
Would clutch friction material be magnetic enough to stick to the drain plug? I would be concerned to say the least.
r_einan is offline
post #5 of 20 (permalink) Old 05-05-2016, 10:27 PM
Who knows what it is without taking it apart. Like I said before, I'd open it up or bring it to someone to open it up to make sure everything is good.
post #6 of 20 (permalink) Old 05-05-2016, 11:14 PM
Are the Lil splinters...very thin and sharp as hell, break easy and briddle?
reds4 is offline
post #7 of 20 (permalink) Old 05-06-2016, 04:17 AM Thread Starter
cookie114's Avatar
Yes, just like that
post #8 of 20 (permalink) Old 05-06-2016, 04:33 AM Thread Starter
cookie114's Avatar
Shifts and runs fine. No engine/primary work done since new
post #9 of 20 (permalink) Old 05-06-2016, 07:07 AM
Smarty's Avatar
I would drop the floor boards and remove the primary cover and inspect. Look closely for wear or any other signs of pieces of metal. Find out what it is before you ride it anymore. Inspect the clutch plates and the metal plates that are in between the clutch plates. Look at the adjusting arm on the primary chain adjuster. I think it safe to say it's not from the rotor/stater system. I hope it's not a piece of a bearing race walking out.
rlaf75 likes this.
2016 RGS Black Quartz
Smarty is offline
post #10 of 20 (permalink) Old 05-06-2016, 07:58 AM Thread Starter
cookie114's Avatar
Umm, sounds bad. That's a trip to the stealer cause I sure can't do mechanic work. I've got esp on the bike so maybe they will take care of it....
Smarty likes this.
Metal Flakes on Transmission Plug milesdt85 Troubleshooting for Road Glides 10 06-14-2018 04:46 PM
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 11:17 AM
Yellow Metal from Primary/Engine Oil milesdt85 Troubleshooting for Road Glides 37 03-23-2014 09:17 AM
Primary drain plug has a lot of metal shreds fat boy ultra Troubleshooting for Road Glides 8 05-14-2013 12:45 AM
Loud metal to metal sound in engine ??? jacksonfdny *General Road Glide Discussions/Pictures 15 09-09-2012 10:48 PM
