engine oil light - Road Glide Forums
post #1 of 2 (permalink) Old 05-08-2016, 07:18 AM Thread Starter
engine oil light
I have a 2016 Road Glide Ultra. Just had my 1000 mile maintenance from my dealer last week. I put about 100 miles on it yesterday, and was doing some cleaning on it afterwords, and decided to fill it up, started bike, and oil lamp came on. I called my dealership, and he said if I was not hearing obvious clanking with the engine, it was probably a faulty sensor. My oil levels were full by the way, which I told him. I did hit the info button, and oil pressure was at 18 when idling. Any thoughts about the light coming on.
MNglideguy is offline
post #2 of 2 (permalink) Old 05-08-2016, 07:43 AM
smitty901's Avatar
You should take it in and have the sensor tested. Most likely that is the issue . Better safe than sorry.
As far as 18 at idle , how hot was it , was it in parade mode all important questions.
Most if not all modern engines use low draw oil pumps. They run at lower pressures .
smitty901 is offline
Service Engine Light, Battery Light and 11 Volts, 13 FLTRX shane_huskey Troubleshooting for Road Glides 6 02-17-2018 05:16 PM
Cold start engine RPM on 107 engine 96349 Engine Related 3 11-07-2017 08:22 AM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
Engine Light and Batt Light come on at same time Hintontm Troubleshooting for Road Glides 8 05-12-2012 07:37 AM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 08:01 AM
