+1 oil pan - Road Glide Forums
  • 1 Post By Hillsidecycle.com
post #1 of 3 (permalink) Old 05-12-2016, 10:33 PM Thread Starter
Darreldanger's Avatar
+1 oil pan
Any one using the Baker or HD +1 engine oil pan and does it help lower the oil temp
Darreldanger is offline
post #2 of 3 (permalink) Old 05-13-2016, 06:21 AM
Once all the oil is circulated, it is all the same temp.
If you want to cool things off, look at an Ultra Cool set up.
Scott
Smarty likes this.
Hillsidecycle.com is offline
post #3 of 3 (permalink) Old 05-13-2016, 06:47 AM
RGKen's Avatar
It does take a little longer for the oil to circulate back through the engine so it does cool it a little bit more. It is not a difference you will feel while riding but even if it's only 5 degrees that is a fair amount for the engine. That however is not enough to justify the price of either of those oversized oil pans IMHO. I think the better benefit if you get a good deal on one is that since there is more oil, its cycle through the engine is larger so in theory it could help the oil last a little longer so you may go more mile between oil changes. The down side is that it will cost you the price of 1 quart of oil more at every oil change. I had one installed while having some warranty work done so I didn't have to pay labor and they gave me an incredible deal on the price of the pan, otherwise I can't say I would spend the money on this. If you have a stock engine and you are just looking for a way to make it feel less hot on your legs then this is not the answer. I do however like having more oil cycled the engine, especially on larger displacement engines. Hope this helps.
Oh and I also now have the UltaCool oil cooler and that is where I would spend the money first.
2018 FLTRXS
RGKen is offline
The $30 HD oil pan... SilverGhost Do-IT-Yourself 16 07-31-2012 10:43 PM
oil pan fastners lldsilver41 Intake and Exhaust 3 02-22-2012 11:59 AM
Baker's +1.5 oil pan Bill Golightly Aftermarket Accessories 10 10-11-2011 10:39 AM
Baker Plus One Oil Pan 103_FBob Engine Related 10 07-28-2011 10:32 AM
Baker Plus One Oil Pan Tytanium Engine Related 0 05-17-2011 06:16 AM
