2012 CVO cam upgrade - Road Glide Forums
post #1 of 5 (permalink) Old 12-23-2012, 08:04 AM Thread Starter
Ok ..... need some help , want to change the cams and not sure what to use ! I have already installed high outputs with power duals and a screaming eagle tuner, so what would be the best set up for me ?
harley junkie is offline
post #2 of 5 (permalink) Old 12-23-2012, 09:20 AM
FLTR2008Trike's Avatar
What have to decide is how you ride first, Two up or solo, do you like to race your bike?
Then do you have a extended warranty, If so do you want to jeopardize it with performace work?
Then how much money you want to spend? From there the choices can be few to many.
There are a number of good shops such Dragos Performance, Hillside Cyles, R&R Cycles, TMan Performance, King of Cubes, Headquaters, Fuel Moto, to name a few who can setup you with a performance package that will get you what your looking for
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #3 of 5 (permalink) Old 12-23-2012, 01:18 PM Thread Starter
Thanks for the info on who to call, I have been looking at the Fuel Moto site and would like to call, living in Ontario, the shops are few to choose from. I want a cam that will give me a little more punch on the highways....
post #4 of 5 (permalink) Old 12-23-2012, 03:13 PM
Since your in Ontario you might want to call these guys as well, they are in your area >> http://www.head-quarters.com/index.html
post #5 of 5 (permalink) Old 12-23-2012, 04:01 PM
faststan's Avatar
Since it is a CVO it should already have the SE 255 cams.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
2012 103: to Cam or not to Cam? 57Glide *General Road Glide Discussions/Pictures 13 02-09-2017 07:09 PM
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
Cam upgrade craigv65 Engine Related 12 01-30-2012 08:26 AM
screamin eagle cam plate upgrade fredflintstone Engine Related 6 01-01-2011 12:19 PM
