Compression release - Road Glide Forums
post #1 of 5 (permalink) Old 05-15-2016, 08:13 PM Thread Starter
Olskoo's Avatar
Compression release
I was riding back from a bike show yesterday and just twisted the throttle and sounded as if I had a spark plug came loose! Pulled over to find my rear head compression release was gone. Has anyone experienced this? Can I just replace the one or better to do both?
Olskoo is offline
post #2 of 5 (permalink) Old 05-15-2016, 09:04 PM
hifiho's Avatar
I've got manual compression releases on my 113. Never had one come loose. I HAVE checked during off-season, and never had issue. If a shop did the install, I'd expect THEM to replace it. Loctite should have prevented that from happening. I don't see any reason to replace both- unless you can only buy a pair.
'15 Road Glide Special...'08 Night Rod Special...'04 Stage 4 113 CI Softail Deuce (Beast Mode)
hifiho is offline
post #3 of 5 (permalink) Old 05-15-2016, 11:38 PM
I have run manual releases for a couple years in my 09. Never had one fall out, I have had the button fall off of one. Had to replace a couple for closing before the bike starts. I always use anti seize not thread locker. The threads are very fine and could be damaged easily. Just tighten them up good and snug don't go crazy. Also check the threads are in good condition in the head before installing the new one.
Reddobe1 is offline
post #4 of 5 (permalink) Old 05-16-2016, 12:02 AM
SMOKENJOE's Avatar
I run s&s easy start cams you dont need a compression release with them
SMOKENJOE is offline
post #5 of 5 (permalink) Old 05-16-2016, 01:11 AM
hifiho's Avatar
Although I've got the compression releases, I was still shredding starters. I swapped to the Easy Start cams as well. Problems solved. I still push the buttons on the releases out of habit. The bike's carbureted, so it takes a while for fuel delivery. With the RG in the stable, that bike doesn't get ridden as much as it should.
hifiho is offline
Compression Release ?? taw8987 Engine Related 10 11-07-2015 11:37 AM
Manual compression release to ACR kit Reddobe1 Engine Related 2 08-18-2015 11:03 AM
Compression Release Ironrider Engine Related 19 11-26-2012 11:24 PM
compression release billd76 Troubleshooting for Road Glides 15 09-11-2012 07:37 AM
9:1, 10:1, 10:5 compression? RoadGlide0611 Engine Related 10 12-09-2010 07:51 AM
