Zippers Performance Parts - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 05-19-2016, 03:10 PM Thread Starter
08Zinc's Avatar
Reading the recent threads on the Andrews cams was interesting, however, I went to a local indy shop for an open house and spoke with some of the Zippers crew that had a booth set up there. After the nightmares of my 2011 Roadie Ultra Stage 4 kit from Harley, I am loathe to have anyone tear into the cases, but want more performance then the AC & slip-ons that I have now. Zippers provided some good thoughts for what I may want to spend from their 107" kit to the more cost palatable .526 cams with a couple of other parts to assist with longevity - oil bypass valve, cam tensioners, and T-Max. Bike currently just has a flash form dealer, so no current tuner.
Does anyone have experience with Zippers? As good as Andrews with similar grind? (I'm looking for low and mid range and these come on at 2250 RPM)
Blessings, Zinc -
08Zinc is offline
post #2 of 14 (permalink) Old 05-19-2016, 04:57 PM
I did Zippers 103" muscle kit (among other things...see below lol!) and I couldn't be happier. 16K flawless miles and it's a rocket! My builder has been using their kits for years and swears by them.
08Zinc likes this.
107 w/ T-Man cylinders and pistons, Zipper's stage 3 heads, Feuling 594 reaper cams, HPI 58mm elliptical TB, S&S roller rockers+forged shafts+premium lifters, TMax, D&D, S&S cam plate+pump, Evolution clutch+no comp sprocket, Baker chain tensioner, bottom end by Revolution w/H beams+Timken, Jagg w/fan, Baker DD7 & +1.5 pan, 14" Vindikta bars, Legend Axeo cartridge forks+Revo-A, HD Blade 18+18, Daymakers, Russell Day-Long.
G Ogre is offline
post #3 of 14 (permalink) Old 05-20-2016, 05:59 AM
'05Train's Avatar
I used to live and work 10 minutes from Zipper's. My bike has never been there and I've never spent a dime with them. I wouldn't use them for lawnmower parts.
jeff338wm likes this.
'05Train is offline
post #4 of 14 (permalink) Old 05-20-2016, 06:22 AM
09Sharknose's Avatar
What problems dos you have with the Harley stage IV? I have it on my '13 and haven't had any issues. Should I expect some in the future?
09Sharknose is offline
post #5 of 14 (permalink) Old 05-20-2016, 06:44 AM
Low-mid power?
Set the compression at 10.0.
Use either a Wood 5-6, or a Cyclerama .575, with some mild head work.
Tune it and ride.
Scott
08Zinc likes this.
Hillsidecycle.com is offline
post #6 of 14 (permalink) Old 05-20-2016, 08:29 AM
Nordic Berserker's Avatar
I have no experience with zippers products so I can't really comment on them. But I can vouch for the woods TW5-6, nice tq comes on early & is what you want in a touring bike. At 2500 rpm I'm already over 120tq with my 107" kit. (Top 116.9 HP & 136.1 TQ)
Nordic Berserker is offline
post #7 of 14 (permalink) Old 05-20-2016, 09:38 AM Thread Starter
08Zinc's Avatar
I used to live near there old shop. Why haven't you used them? I'm just doing homework prior to jumping in. Thanks.
Blessings, Zinc -
08Zinc is offline
post #8 of 14 (permalink) Old 05-20-2016, 09:43 AM Thread Starter
08Zinc's Avatar
It's all documented here: https://www.roadglide.org/26-engine-r...stage-4-a.html Not sure how much was the dealer - I suspect most of it.
Blessings, Zinc -
08Zinc is offline
post #9 of 14 (permalink) Old 05-20-2016, 09:46 AM Thread Starter
08Zinc's Avatar
Geez! Nice torque numbers. What 107" kit did you go with?
Blessings, Zinc -
08Zinc is offline
post #10 of 14 (permalink) Old 05-20-2016, 10:06 AM
Rosa's Motorcycle Shop | Harley Davidson Specialists
08Zinc likes this.
SWIII sponsor ZIPPERS PERFORMANCE TracyB ARCHIVES-SWIII St. George, UT 26 06-18-2013 12:29 PM
Zippers Performance Thundermax Autotuner sailsteady Sold 2 11-30-2012 07:55 AM
D&D Fat Cat 2-1, Zippers ThunderMax, SE Air & SE204's capt3017 Road Glide Builds-Document your builds HERE --NEW 8 03-23-2012 08:47 AM
HD tuner/zippers/PC-V RoadGlide0611 ECM/Fuel Management systems 30 02-20-2011 08:05 AM
zippers roadgliderick ECM/Fuel Management systems 5 11-23-2010 10:22 PM
