Oil Leak, 2016 RGU - Road Glide Forums
 4Likes
post #1 of 16 (permalink) Old 05-21-2016, 09:42 AM Thread Starter
Oil Leak, 2016 RGU
I have had this persistent oil leak since new, and it seems to be getting a bit worse now. 1850 miles on the bike (the WX has been terrible here since I bought it in mid-Feb)
It appears to be leaking from the rear case seem then running down and spreading.
The pics below are from about 125 miles of drive time. Engine used since the 1k service is the HD Syn3.
The dealer wants to split the cases to reseal, and has asked if I wanted any engine "upgrades" since the labor would be basically free.
This is the main question here...What to do, if anything? I am more interested in reliability than max power output, and not really interested in it being super load, but I was planning at least a stage one tune and pipe to delete the CAT to lower temps and get a bit of performance boost. Obviously none of that requires splitting the cases. I've read about cams and crank welding-but it's all very overwhelming and I'm trying to learn all I can.
This is my first Harley, I come from Gold Wings that never leaked a drop, so I am a bit disappointed in this-all other aspects of the bike are fantastic, but having to do this major repair that has the potential to lead to even more problems has me a bit pissed at the moment
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Kennyd is offline
post #2 of 16 (permalink) Old 05-21-2016, 10:08 AM
sj01fltri's Avatar
My 12 RG did the same thing,they pulled the rear cly and filled the gap with case sealer without splitting the cases.Bike had 1200 miles on it when this was done traded it in with 30,000 on it and it stayed dry.As far as up grades i would consider having the crank welded and and balanced at this time,the rushmores run pretty strong as is,the head pipe and air cleaner would be a good option with a flash.
sj01fltri is offline
post #3 of 16 (permalink) Old 05-21-2016, 10:19 AM
'05Train's Avatar
You're under warranty, so I'd let them do what they're going to do. Frederick's got a decent service department, and Battley's gotten much better over the past few years.
I would't worry about doing any upgrades.
'05Train is offline
post #4 of 16 (permalink) Old 05-21-2016, 10:30 AM
twowheeladdict's Avatar
I will hit 5000 miles by next weekend. No leaks yet.
I am only making comfort mods to this bike. Not sure if it is a long term ride yet.
twowheeladdict is offline
post #5 of 16 (permalink) Old 05-21-2016, 10:43 AM
Desertwndrr's Avatar
KennyD,
I'd suggest having the flywheels trued and welded if you are going into it that far. Maybe the Timkin upgrade, but certainly the "hefty lefty" bearing upgrade, whichever is easiest. Those are both piece of mind issues and fairly inexpensive.
If they are willing to do the labor for free then you have plenty of performance upgrades to consider. It all just depends on budget. If it were me, I'd suggest building up a 117" if you can swing it but that isn't cheap.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #6 of 16 (permalink) Old 05-21-2016, 11:01 AM
'05Train's Avatar
Uhh, guys......Kenny's got a stock bike and is planning on doing a Stage 1 at some point. Welding/truing the crank and the Timken conversions are going to run him upwards of $1,200, have his bike off the road for at least 10 days, and are completely unnecessary for what he's got planned.
tdkkart likes this.
'05Train is offline
post #7 of 16 (permalink) Old 05-21-2016, 12:11 PM
Agree welding & truing the crank isn't necessary for a 103 with stage 1 upgrades.
I would look carefully at the leak, the pictures make it hard to determine where the leak is coming from but to me it looks as if the cylinder base gasket is the source of the leak.
It is not uncommon for the cylinder base gasket to leak even on a new engine, the main reason the cylinder base gasket leaks is because the o-ring was over oiled during assembly, in most cases the leak is just the excess oil seeping out from under the cylinder and it will stop over time. If the base gasket is the source of the leak there is no need to split the crankcase.
The bike is under warranty so let the dealer address the repair but the only performance mod I would consider is a cam upgrade even though the stock 103 HO cam isn't too bad of a cam and adjustable push rods.
post #8 of 16 (permalink) Old 05-21-2016, 01:18 PM
Don't be too pissed. NW as they will fix it. Shit happens. Leave it stock as the reliability is what your after. That engine will get you where you want to go and back as fast as you need to go!
Ride it as stock and enjoy. Do your stage one; ride it and enjoy! Then in the future if your not happy with the performance, push the performance. But out of the box it does perform well.
My 15 had a pinced o ring at assembly. Showed tge leak at 100 miles. They fixed it then and there and now at 10,000 its just a memory. ENJOY IT AS IT IS.
sh1520 likes this.
Drampy is offline
post #9 of 16 (permalink) Old 05-21-2016, 01:50 PM
And I've had a stock CVO bottom end scissor. Putting a small amount of money in that bottom end will provide a solid foundation should he decide to upgrade the motor down the road.
sj01fltri likes this.
post #10 of 16 (permalink) Old 05-21-2016, 02:04 PM
I can't believe train actually said leave it alone! He finally listened to what I say!
Fix it and leave alone, the more you do the more you create other problems, just my 2 cents
2013 RGU, black of course....
y2kflhr is offline
Oil leak on 2016 Road Glide sj01fltri *General Road Glide Discussions/Pictures 27 12-22-2015 06:44 PM
2016 RGU oil report... FLTRI *General Road Glide Discussions/Pictures 14 10-17-2015 01:28 PM
New RGU with oil leak Don-T *General Road Glide Discussions/Pictures 9 09-04-2013 09:22 AM
Oil Leak? Primary Leak? shutzund Troubleshooting for Road Glides 4 06-04-2013 08:55 PM
2011 RGU oil leak fixed sanders Road Glide Specific Discussions 2 09-15-2011 07:21 PM
