What octane do you use? Is it really best?? - Road Glide Forums
 29Likes
post #1 of 83 (permalink) Old 05-21-2016, 01:07 PM Thread Starter
! rock103 !'s Avatar
Just out of conversation sake, I would like to find out what y'all thoughts were. I know the HD owners manual suggests 91 octane minimum and is what I have been doing for years in my HDs. But is it really any better, or worth the cost? I came across this video and have to say, I have my doubts. And how much 91 octane are we really pumping into our small tanks after someone pumped 87? Chances are, in my way of thinking, very little as the fuel travels a long way through hoses to get from the pump to my tank...
https://www.youtube.com/watch?v=FPPkPAbzwbU
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #2 of 83 (permalink) Old 05-21-2016, 01:54 PM
mpholland's Avatar
I just filled up with 93 octane ethanol free yesterday @ 3.89/gal. It was either that or 87.
Normally, in a water cooled engine you can get away with whatever octane will keep you from detonating. If your CR isn't too high or timing to far advanced, that usually means 87 is fine. With an air cooled engine, that doesn't necessarily hold true, as detonation is also a product of cylinder head temperature. In the winter I can usually get away with running 89. When it gets hot out, I always run 92 or better , if possible, especially if I know I am going to be doing much stop and go where the bike won't be moving a lot.
MightyWhitey likes this.
Rest in Peace Michael Wade
mpholland is offline
post #3 of 83 (permalink) Old 05-21-2016, 02:33 PM
'05Train's Avatar
I use the highest octane I can, as that's how I tuned the bike. And I beat on it like I'm Ike Turner.
'05Train is offline
post #4 of 83 (permalink) Old 05-21-2016, 02:46 PM
immo2896's Avatar
That is funny right there!!!!
and I do the same as far as the highest they have.
immo2896 is offline
post #5 of 83 (permalink) Old 05-21-2016, 02:59 PM
JacktheBagger's Avatar
another for the highest octane available , mostly around here it's 91 or 92 or 93 at entec , cost a bit more , but what the hay ..
2011 Ultra
JacktheBagger is online now
post #6 of 83 (permalink) Old 05-21-2016, 03:13 PM
bobbybones's Avatar
I use 93 if they have it I tried 91 and seem to get valve noise now nothing so I will stick with93
bobbybones is offline
post #7 of 83 (permalink) Old 05-21-2016, 04:25 PM
RGKen's Avatar
If your compression is below around 10:1 you could probably get away with a mid grade but for higher compression I wouldn't use anything less than Premium. The octane rating is just how well it resist detonation. The higher the number the higher the resistance. If your bike has been tuned by a certified tuner I would consult them.
Jacksprat56 likes this.
2018 FLTRXS
RGKen is offline
post #8 of 83 (permalink) Old 05-21-2016, 04:40 PM Thread Starter
How much of that higher octane fuel are you actually pumping into the tank though after someone filled the lines with god knows what. Probably lowest octane...I am curious to find out. Always wondered that. Even so, I still pump in the higher octanes in the bike. But pump the cheapest petro in my cage.
shrknz and bigqdiddy like this.
post #9 of 83 (permalink) Old 05-21-2016, 05:52 PM
I used 89 last summer to experiment. I'm about at sea level and running stock compression. It ran just fine and didn't notice any detention. The bike seemed to run hotter though. After about a month I switched back to 93.
Big_gary is online now
post #10 of 83 (permalink) Old 05-21-2016, 06:28 PM
09Sharknose's Avatar
According to the WSJ article below, there is only about 1/3 gallon of previous fuel remaining in the average pump. On average, I put about 5 gallons in when I fill my tank.
Assuming 5 gallons of 93 octane being pumped in and 1/3 of a tank of 87 gas left in the pump, the octane of the fuel added is about 92.6. Well above the requirement.
Science doesn't lie, your mechanic does.
Done.
http://www.wsj.com/articles/SB122944043385810527
09Sharknose is offline
Octane "would you rather" post. #deadhorse Thegreencantina Fluids and Lubricants 22 04-16-2014 12:07 AM
do really need new style grilles for 2004 and older rg to use 6.5 adapter rings dirtracer27x Audio 0 08-30-2012 05:18 PM
Detatchable covers- Really HD, this is the best you can do??!? Govdog76 Equipment-RG 10 02-26-2012 06:44 PM
Does Anyone Use Octane Boost in 103 b104396 Road Glide Specific Discussions 23 08-07-2011 01:21 PM
What is the best fuel octane rating for HD RG Big Red 103 General Off-Topic Discussions 19 11-26-2010 11:48 PM
