upgrade - Road Glide Forums
post #1 of 12 (permalink) Old 05-29-2016, 03:29 PM Thread Starter
upgrade
Hi all.
After researching, I either can not find what I am looking for or what I find is over my head
I have a stage 1 with SE breather, Fulsac headers, SE mufflers, and all dynotuned.
So, I was looking to see what an upgrade to cams might do, and will that quiet down the motor a bit. I have wrenched on my bike and can follow good instructions if need be.
Suggestions?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 12 (permalink) Old 05-30-2016, 10:52 AM
upgrade
what is it that you want to do ?? i would be willing to give you better info if you were to write to me at my mail address. [email protected]
dsvracer is offline
post #3 of 12 (permalink) Old 05-30-2016, 11:57 AM
If you have the service manual for your bike the instructions to do a cam install is in the manual!.
You should replace the inner cam bearing when doing a cam mod and you need a cam bearing removal/installation tool to do this.
If you don't have adjustable pushrods in your bike then you will need to either take off the rocker assembly to remove the pushrods or cut the pushrods and replace them with adjustable pushrods.
A low end mid range torque cam is the best choice for the touring model bikes and if you stay around .555 lift it isn't as hard on the valve springs and will keep the top end a little bit quieter the a higher lift cam.
post #4 of 12 (permalink) Old 05-30-2016, 04:11 PM Thread Starter
I do have the manual but at this point dont feel confident enough to do it.
I was thinking of having the dealer do the install and then dyno tune. I guess I dont want the dealer to oversell things.
Overall, I would like a bit more of everything. I am not a speed shifter or WOT and go all the time type. I just want it to be there when I need it or when I want it.
I
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #5 of 12 (permalink) Old 05-30-2016, 04:21 PM
apgharleymech's Avatar
If you're close to Kingman, AZ, I'm more than willing to offer my services. I'm a Harley Davidson certified mechanic working at their test site up here, always willing for some side work and to help someone out.
Drampy likes this.
apgharleymech is offline
post #6 of 12 (permalink) Old 05-31-2016, 06:22 AM
Originally Posted by pauld View Post
Hi all.
Suggestions?
A Cyclerama .570, or an Andrews 48 are 2 good choices for plug/play cams in that 2013(?).
Scott
Hillsidecycle.com is offline
post #7 of 12 (permalink) Old 05-31-2016, 11:26 AM
MyGlide's Avatar
Pretty good offer right there. Changing cams and bearings can be a little intimidating the first time you do it yourself but it.s really not that difficult just a little tedious. Here's a good link that goes through it.
https://www.youtube.com/watch?v=n5KvamRqCis
2018 KTM Super Duke R
MyGlide is offline
post #8 of 12 (permalink) Old 06-10-2016, 06:55 AM
If willing to pull the heads, and some mild work in key areas, and a Cyclerama .575 is a home run also.
Scott
post #9 of 12 (permalink) Old 06-10-2016, 07:29 AM
Smarty's Avatar
Scott
Hey Scott, what could someone expect out of the Cyclerama .575, headwork with 1.9" intake valves, 2n1 Fat Cats and heavy breather. Any guesses on Hp/Tq.?
2016 RGS Black Quartz
Smarty is offline
post #10 of 12 (permalink) Old 06-10-2016, 08:46 AM
Durwood (Shafer Performance) tuned a 103" with stock pistons, Dan Vance heads and CR575, 110.41hp/118.45tq SAE. Breaks 110 ft lbs @ 2700 rpm. Stout.
rg113 is offline
2010 Fairing Support Upgrade With HD Vented Lowers!!! CCRydah Aftermarket Accessories 162 06-13-2011 10:16 AM
fairing support upgrade prices JacktheBagger Aftermarket Accessories 2 05-12-2010 02:15 PM
Suspension upgrade Grego Aftermarket Accessories 3 04-11-2010 04:47 AM
Upgrade! firecap1962 *General Road Glide Discussions/Pictures 11 03-27-2010 08:02 AM
Wife O.K.'s all upgrade purchases joke *General Road Glide Discussions/Pictures 21 02-16-2010 11:16 AM
