Revolution performance - Road Glide Forums
post #1 of 31 (permalink) Old 01-02-2013, 10:43 PM Thread Starter
spokanebagfan's Avatar
Got email from rev performance and if you buy a big bore kit they do your crank for free. Just wanted to share. I have seen a lot of builders use their kits and really like them. Hope someone uses it.
spokanebagfan is offline
post #2 of 31 (permalink) Old 01-02-2013, 11:07 PM
I wish they wouldve had that offer when I did mine. I have a 103 in the garage, maybe I should see if they'll work a deal, wouldn't mind having a 117.
Sent from my SPH-L710 using Motorcycle.com Free App
post #3 of 31 (permalink) Old 01-03-2013, 02:09 PM
prodrag1320
Guest
Posts: n/a
run like hell away from their NIKASIL cylinder kits,many,many problems
post #4 of 31 (permalink) Old 01-03-2013, 02:24 PM Thread Starter
Pro what do you mean? i have heard there was alot of issues with their first generation cylinders, but if heat cycled the right way i have heard the 2nd gen stuff is top notch.
post #5 of 31 (permalink) Old 01-03-2013, 07:56 PM
mocotom's Avatar
Have you had failures with these cylinders?
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 31 (permalink) Old 01-03-2013, 08:08 PM
I've heard the same thing, I haven't had any problems, I would like to hear more.
post #7 of 31 (permalink) Old 01-03-2013, 08:41 PM
Phil_FLTRX's Avatar
I have their 107 kit with 12000 miles and no issues. I sure as well wish they had done my crank for free. Damn!!!!!
2011 Vivid Black FLTRX, 107" Rev Perf, Zippers Thundermax AT, Roland Sands Speed 7 AC, Iron Aces iPhone holder, 8" KW, V&H Duals & Black Widows, DDM HIDs, ARC 6.5's, S.E. ported heads, 30 tooth frt sprocket.
You never see a Harley parked outside of a Psychiatrist’s office, now do you.....
Phil_FLTRX is offline
post #8 of 31 (permalink) Old 01-04-2013, 10:54 AM
equandt's Avatar
Not sure about the Rev Perf Nikasil cylinders, but they completely botched a set of my cylinder heads...twice! I finally just walked away and went with another shop that put together a good set of ported heads for my build.
I know some say good, some say bad. Leads me to think they may have some process quality control issues.
prodrag1320 knows his stuff. I'd follow his advice.
equandt is offline
post #9 of 31 (permalink) Old 01-04-2013, 12:22 PM
prodrag1320
Guest
Posts: n/a
the NIKASIL has been coming off the cylinders & having catasrophic results,not to sat EVERY kit has problems,but its WAY more than they should.guys that have had problems are told they installed it wrong,wasnt clean enough,wrong tune,ect,ect.but NEVER their fault.i dont see any reason for NIKASIL cylinders anyway,no real advantages over regular cast sleaves & very few shops have the diamond honing stones to work on them
post #10 of 31 (permalink) Old 01-04-2013, 04:59 PM
FastestBagger09
Guest
Posts: n/a
I could'nt disagree with you more.Thats an issue they had in the past that has been long since remedied.I've been running they're cylinders for 4yrs. now without any issues.I know of numerous other bikes with not one issue.Nikasil cylinders are used by a number of other companies without any issues.
FS: PRECISION™ ENGINE MANAGEMENT SYSTEM by Revolution Performance direwolf Parts for Sale 0 05-06-2013 12:24 PM
Revolution Performance Big Bore Kits?? Nevadasun Engine Related 10 02-12-2013 10:07 AM
revolution monster big bore 107" for tc? dirtracer27x Engine Related 13 08-29-2012 07:33 AM
revolution performance EMS spokanebagfan ECM/Fuel Management systems 11 06-02-2012 09:58 AM
Revolution Precision EMS Install Overview fuelmoto ECM/Fuel Management systems 2 02-25-2011 05:09 AM
