High Compression Pistons for the HD 110 Upgrade kit - input - Road Glide Forums
post #1 of 3 (permalink) Old 06-16-2016, 08:05 AM Thread Starter
I picked up the HD 110 Upgrade kit to take the 103 to a 110 as my bike (2012 FLTRX) is already a stage 4. HD advertises it as an upgrade if you already have a stage 4. Finally got around to opening it and the pistons are not high compression.
Where could I find some 10.5 pistons for this kit?
The part number that I'm talking about is
SKU 92500039
Thanks
oc357 is offline
post #2 of 3 (permalink) Old 06-17-2016, 06:43 AM
My suggestion would be to contact the place of purchase, or contract J&E, or Wiseco (one in the same) for custom pistons.
You'll need to probably buy 4 pcs if doing the later, and they will need for you to fill out a complete detailed worksheet as to the precision dimensions you are looking for.
Scott
Hillsidecycle.com is offline
post #3 of 3 (permalink) Old 06-17-2016, 07:05 AM
I would contact the dealer you purchased the kit from and let them know that you wanted the Tire Shedder kit. It comes with 10.5 to 1 pistons, maybe they will exchange them for you. The worst that can happen is they say no.
Jims79FLH is offline
11.25 pistons added what’s the compression? freedom1974 Engine Related 57 01-31-2018 12:04 AM
SE 110" Cylinders, Heads, Pistons, ETC... ThumperGA Parts for Sale 8 06-19-2017 01:25 PM
High compression pistons chefskeeter Engine Related 18 04-13-2013 08:15 AM
95'' heads high compression pistons and cams OuchMMC Dyno Results 18 04-04-2012 12:14 AM
