Screaming Eagle Oil Pump - Road Glide Forums
post #1 of 14 (permalink) Old 01-05-2013, 03:19 PM Thread Starter
Illiniroads's Avatar
My bike is in for new cams and dyno. Dealer is recommending replacing my oil pump and plate with SE version. What is the forum consensus on this oil pump thingy?
2012 RGC BIG Blue Pearl SE Stage II 95hp 107tq
2011 RS-S Can Am Spyder 106hp 77tq
Illiniroads is offline
post #2 of 14 (permalink) Old 01-05-2013, 03:26 PM
tmd
Not needed on the newer engines, dealer is just trying to pad the profit.
tmd is offline
post #3 of 14 (permalink) Old 01-05-2013, 03:28 PM
faststan's Avatar
Depending on miles. Replace the chain tensioners and possibly oil pump. JMO.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #4 of 14 (permalink) Old 01-05-2013, 03:47 PM
mocotom's Avatar
If the factory pump is not damaged or scored, there is no need to replace.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 14 (permalink) Old 01-05-2013, 05:55 PM
qkshift's Avatar
They claim it stops blow by if that is problem you have or it would bother you,you may think about it.I get it at about 4500 miles it shows up clean the filter and do my oil change so It don't bother me.
qkshift is offline
post #6 of 14 (permalink) Old 01-06-2013, 12:07 PM
No real need to upgrade to the SE oil pump the stock oil pump works just fine, there is no need to replace the cam chain tensioners either if the tensioner shoes look good. What upgrade you should do is to put in new Timken inner cam bearings and make sure the dealer puts new o-rings in the oil pump. This would also be a good time to upgrade to the SE adjustable push rods IMO doing this upgrade will cut down labor cost if the cam chest needs to be opened up for repairs later on.
post #7 of 14 (permalink) Old 01-06-2013, 12:20 PM
Peewee's Avatar
If you have the spring loaded tensioners than I would recommend the upgrade. It converts you over to the new hydrolic style (much longer life) and it comes with the new oil pump. The new pump is a high volume in comparison to the old style. If you have ever priced a new oil pump, you are basicly getting the new cam plate and tensioners for free. Just my. 02
Sent from my DROID RAZR using Motorcycle.com Free App
"Know Thyself"
Peewee is offline
post #8 of 14 (permalink) Old 01-06-2013, 12:54 PM
This is true if you have the 88" twin cam engine in your 06 and earlier model bike. In the OP signature he has a 2012 model bike so his bike already has the new cam plate with high volume oil pump and hydraulic cam chain tensioners.
post #9 of 14 (permalink) Old 01-06-2013, 12:55 PM
mdemoulin's Avatar
I have a 2013 with a stage 4 done. I asked that same question about an upgraded oil pump and plate. My son did the stage 4, he is a Harley mechanic, he asked one of the master techs of 17 years about the oil pump he said it was not needed on the newer engines. save yourself $500.
2013 Big Blue Pearl Road Glide
Stage 4 upgrade/SE Heavy Breather
259e cams
mdemoulin is offline
post #10 of 14 (permalink) Old 01-06-2013, 03:18 PM
Bigtrev8xl's Avatar
Why do it now,it won't save anything.
How can changing push rods be considered an "upgrade"?
I DON'T DO RUSHING!
Bigtrev8xl is offline
Screaming eagle high capacity oil pan easybiker Parts for Sale 9 12-18-2013 10:39 PM
Screaming Eagle FatShotz MarAgt Intake and Exhaust 6 05-28-2010 12:59 AM
Stage 1 & Screaming Eagle Exhaust buzzman_45011 Intake and Exhaust 4 05-17-2010 11:12 AM
New Screaming Eagle slip on sundance10000 Intake and Exhaust 12 03-27-2010 07:52 AM
2010 FLTRX 2-1 Exhaust Slip-On Screaming Eagle Nightstick zuppy51 Intake and Exhaust 15 02-23-2010 08:01 AM
