octane boost - Road Glide Forums
  • 1 Post By smitty901
post #1 of 4 (permalink) Old 06-17-2016, 10:51 AM Thread Starter
octane boost
does it hurt a 06 glide to run octane boost in a 06 glide?
redbone is offline
post #2 of 4 (permalink) Old 06-17-2016, 11:05 AM
My Indy told me not to use it. He says it's extremely hard on spark plugs and is actually primarily for racing applications. I ran it in my 13 for a while before talking to him about it. We pulled the plugs on it and they looked like crap. Put in new plugs and have been running them without the octane boost and they still look like new.
2013 Road Glide Ultra, Rhinehart exhaust, Stage IV kit and more.
mstreak1 is offline
post #3 of 4 (permalink) Old 06-17-2016, 12:14 PM
Bike should run fine without octane boost! I use to carry a bottle of octane boost when on road trips because you never know if you can get premium gas at some of the out of the way gas stops. But I only used octane boost for emergencies.
post #4 of 4 (permalink) Old 06-17-2016, 01:11 PM
smitty901's Avatar
Why would you? unless you jacked the compression way up it makes no sense to boost it 91-93 is as good as it gets for most and higher will do nothing for you.
If you are concerned about your fuel system a little sea foam a couple times a year and sleep well you are good to go.
'05Train likes this.
smitty901 is offline
Can octane boost cause BLACKHAWK Troubleshooting for Road Glides 3 08-14-2013 07:49 PM
Dragos new 124 blower motor 6lbs boost only DragoBikeWorks Dyno Results 8 08-05-2013 10:37 AM
120r stock with procharger 8/9 boost DragoBikeWorks Dyno Results 11 07-24-2012 01:08 AM
Does Anyone Use Octane Boost in 103 b104396 Road Glide Specific Discussions 23 08-07-2011 01:21 PM
Octane Boost JacktheBagger ECM/Fuel Management systems 3 04-23-2011 08:00 PM
