Engine Builders... need some input on cams - Road Glide Forums
 8Likes
post #1 of 12 (permalink) Old 06-17-2016, 04:43 PM Thread Starter
Spazz's Avatar
I must say that selecting cams is NOT my in my bag of tricks.... and I need some solid advice on selection.
Im a fairly aggressive rider... I like 3000 rpms and up as of right now and I think that is because I am in the powerband of the SE259E cams. I would like a bit more bottom end as it feels sluggish below 3000rpms.
I ride 2 up when my wife goes with me, but don't make this a factor as its only 10-20% of the time.
I have the 120ST crate motor from HD... its in the shop, torn down right now for oil consumption..rings, valve guide seals and scoring on the walls so far..... and figured since I'm into it, may as well upgrade the cams at this point and save some coin.
I don't want to do additional headwork right now ( maybe never ) and I would like to not have to change out my springs or do any clearancing if needed for said cams.
additional info... Power Vision tuner with Target Tune... 1074X Thunder Header and SE Chiseled extreme AC....
So... what's your advice? I have looked at a few in comparison... but seem to be confusing myself more, since my cam knowledge is not where it should be to make an educated decision on my own.
Thanks guys.. I do appreciate the input.....
RENO BAGGER AUDIO
Spazz is online now
post #2 of 12 (permalink) Old 06-17-2016, 05:59 PM
SMOKENJOE's Avatar
I would ask dragos or hillside for a low end cam my compression is 11 to 1 and i wanted to run a low end cam like a s&s 551 but the told me i had to much compression i ended up with a 585 cam the bike turns on at 2500 rpm and up i had 5 sets ofs&s cams but had to buy the 585 cams i am thinking of running the s&s 640 cams but for now stay with the 585
RGKen and Spazz like this.
SMOKENJOE is offline
post #3 of 12 (permalink) Old 06-17-2016, 06:02 PM
Nordic Berserker's Avatar
Not a builder but heard of some great results with 120's running woods TW9B-6
Nordic Berserker is offline
post #4 of 12 (permalink) Old 06-17-2016, 06:28 PM Thread Starter
Spazz's Avatar
I have heard that as well...thanks. I think that is used in FM'S 124 kit...
RENO BAGGER AUDIO
Spazz is online now
post #5 of 12 (permalink) Old 06-17-2016, 06:39 PM
go on the woods website & click on dyno runs, you'll see a few sheets for each engine size builds with different cams. Mine is up there as well under 107 builds.
Here's one with sheet with that cam & some head work
http://www.woodcarbs.com/images/tc120efitw9b-6-1.jpg
Spazz likes this.
post #6 of 12 (permalink) Old 06-18-2016, 10:11 AM Thread Starter
Spazz's Avatar
Yeah... thanks.... I have been eye-balling this one... just not sure yet....
RENO BAGGER AUDIO
Spazz is online now
post #7 of 12 (permalink) Old 06-18-2016, 11:24 AM
Smarty's Avatar
If you find a woods grind that you like, go to T-man performance. He pretty well copies Woods but has a less aggressive grind on the back side which softens the slamming of the valves and has a lot quieter valve train noise because of it.
Nordic Berserker and Spazz like this.
2016 RGS Black Quartz
Smarty is offline
post #8 of 12 (permalink) Old 06-18-2016, 01:21 PM Thread Starter
Spazz's Avatar
Very good advice. Thanks. They are still specing things out on the damage... once I find out the details ( if cams are warranted) I may be able to swing a deal of offsetting the cost.
Thanks again
RENO BAGGER AUDIO
Spazz is online now
post #9 of 12 (permalink) Old 06-18-2016, 02:42 PM
'Not a Builder, not now anyway...
'Have the T-Man 625s in "The Short Bus" they come in much earlier than the 259s, 120 ftlbs at 2200, start to fall off at 5900, quiet, pulls very well throughout the entire RPM range, 10.4 static... TR recommends 10.2-10.6
A great all around bagger performance cam, I will use nothing else in future Builds...
'Giving 120s & 124s nightmares... PRICELESS
Smarty and Spazz like this.
HeatWave is offline
post #10 of 12 (permalink) Old 06-18-2016, 02:56 PM Thread Starter
Spazz's Avatar
Great details! Thanks a lot! that's what I like to hear.....
This is on the site:
T-Man 625
This cam is a good fit for 74” to 88” motors with 10.2-10.8 compression. It will deliver a smooth torque and power curve from 2400 rpm and still make power past 6000 rpm
So... how do I know this is a good fit for my 120? I see the SHORT BUS is a 117.... so this might be a stupid question.... but still need to ask
RENO BAGGER AUDIO
Spazz is online now
Pacific Northwest engine builders MightyWhitey Engine Related 9 09-07-2017 03:06 PM
ENgine builders your Thoughts New HD motor? Drago's or Hillcountry Tofast4u Engine Related 0 08-24-2016 11:44 AM
ENGINE BUILDERS: I Need an Opinion on High Capacity Oil Pan for 120" RGKen Engine Related 10 05-29-2015 07:46 AM
NC engine builders Kevin0032 Engine Related 11 01-11-2015 04:09 PM
Question for engine builders StGhost Engine Related 6 05-15-2012 07:21 PM
