Help broken down & HD can't fix - Road Glide Forums
 6Likes
post #1 of 23 (permalink) Old 06-23-2016, 03:20 PM Thread Starter
ameleo's Avatar
2011 ultra surging and then backfire. Won't idle. Dealer has changed everything, ecm, injectors, coil, battery, plugs, wires, fuel pump and filter, gas, compression test, etc. No codes. Ran fine for 500 miles. Stopped and when started the problem began. Three techs and service manager working on it for two days.
ameleo is offline
post #2 of 23 (permalink) Old 06-23-2016, 03:35 PM
psrumors's Avatar
I had a Cummins diesel that had issues no one could figure out. After a month in the shop they put a new complete wiring harness in and no more issues.
May be something similar.
psrumors is offline
post #3 of 23 (permalink) Old 06-23-2016, 03:41 PM
JacktheBagger's Avatar
my first thought was air filter , was it changed ?
2011 Ultra
JacktheBagger is offline
post #4 of 23 (permalink) Old 06-23-2016, 03:52 PM
Sincecrazy's Avatar
Cam position sensor?
Taccone likes this.
Sincecrazy is offline
post #5 of 23 (permalink) Old 06-23-2016, 04:17 PM
Sounds like a wire is broken somewhere in the wiring harness and is losing voltage. Not much left after all they done.
post #6 of 23 (permalink) Old 06-23-2016, 04:55 PM
gorillaman's Avatar
Yep... The sensor or some wiring issue... or a Throttle Body leak.
2016 FLTRU Vivid Black
gorillaman is offline
post #7 of 23 (permalink) Old 06-23-2016, 05:05 PM
Sounds like a 'shotgun" fix, they'll be in changing fluid in your pipes next, sincere^ like to technical for em, and me
reds4 is offline
post #8 of 23 (permalink) Old 06-23-2016, 05:51 PM
tdkkart's Avatar
There is no cam position sensor, that went away in 2001 or 2, however it very well could be the crank position sensor.
Taccone likes this.
tdkkart is offline
post #9 of 23 (permalink) Old 06-23-2016, 06:37 PM
Fuel
When did you last get gas?
Drampy is offline
post #10 of 23 (permalink) Old 06-23-2016, 07:18 PM
PGR
PGR's Avatar
Pull your air cleaner assembly, including the backing plate. Fire up the bike, and while the bike idles, push the wires that are above the induction module. You may have to have someone "tickle" the throttle to keep it running.
There is a known issue with the 2011 Mexican made wiring loom having that section of wires that are to short. Eventually a wire will break as the engine rocks in the frame. I had to fix two of those wires on mine.
HoustonUltra likes this.
Ron..........................
PGR is offline
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 03:57 PM
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 07:26 PM
Fix a broken tab on inner fairing? Lunchboxx Do-IT-Yourself 15 07-09-2016 04:42 PM
Broken down in Boston! palmpalm *General Road Glide Discussions/Pictures 112 03-29-2015 11:07 PM
Broken Down AKRoadGlide Troubleshooting for Road Glides 21 08-12-2014 04:44 PM
