Engine Light On - Road Glide Forums
post #1 of 1 (permalink) Old 06-30-2016, 06:56 PM Thread Starter
ERod62's Avatar
Engine Light On
First had the following codes which posted early after a bad riding day.
RGC 2012
Codes;
P0131 Front Oxygen sensor low
P1510 Limp mode
P2127 TGS2 Low/Open
P2138 TGS correlation error
Pn 32999-11 ??? possible throttle position
Reset the code riding trouble free for few days.
Then P1510 Limp Mode and P2127 TGS2 Low/Open repeated through a long day riding.
The TGS seen to be the problem.
Tested device resistance with a meter between pins;
TGS 1
1 to 3 =6K ohms
3 to 2 =176 ohms
2 to 1 =6K ohms
TG 2
4 to 6 =6K ohms
5 to 6 =176 ohms
4 to 5 =6K ohms
No resistance changes when twist the throttle.
Since the problem was intermittent follow through the cable pulling and shaking it. Bingo 1 to 3 circuit braking open. Found wire of pin 3 broken near the neck before going into the fairing.
Just sharing the info the service manual don't give values of the TGS1 and 2 resistance. Only show the wiring circuits.
Back on the saddle trouble free... for now
ERod62 is offline
Service Engine Light, Battery Light and 11 Volts, 13 FLTRX shane_huskey Troubleshooting for Road Glides 6 02-17-2018 05:16 PM
Cold start engine RPM on 107 engine 96349 Engine Related 3 11-07-2017 08:22 AM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 04:59 PM
Engine Light and Batt Light come on at same time Hintontm Troubleshooting for Road Glides 8 05-12-2012 07:37 AM
Oil Overfill and Check Engine light Biker Tom Troubleshooting for Road Glides 5 09-15-2010 08:01 AM
