Oil seeping mid cylinder - Road Glide Forums
 2Likes
post #1 of 11 (permalink) Old 07-01-2016, 12:49 PM Thread Starter
Bigmunkey's Avatar
I have done a few searches and gotten some info, but I wanted to ask here for some opinions.
2013 FLRTU with 14K. I have what appears to be oil seeping from the center portion of the front cylinder on the front face between fins and extending part way around each side. I think it is too low to be a head gasket, and too high to be an O ring as the oil seems to be confined to the 5-6 fins.
I saw some posts about a porous cylinder, but I am not sure if this is what it could possibly be. Of course it is out of warranty so it's my problem, and I was wondering if anyone had any input or if it would hurt to run it and just keep cleaning up the mess.
Any thoughts would be appreciated.
2013 FLTRU, Rush slip ons, Screamin Eagle Stage 1 breather
Bigmunkey is offline
post #2 of 11 (permalink) Old 07-01-2016, 12:55 PM
Bleachey's Avatar
Are you sure you just didn't pick up some road grime?
68_340_Cuda likes this.
2011 Road Glide Ultra
Bleachey is offline
post #3 of 11 (permalink) Old 07-01-2016, 01:06 PM Thread Starter
Bigmunkey's Avatar
Yes. I was hoping that was all it was so I cleaned between the fins about 3 weeks ago. I was also hoping it may be off the oil cooler lines, so I made sure I cleaned them up as well.
It came back on the engine and the lines were still clean. There is also nothing on the frame down tubes or fender.
post #4 of 11 (permalink) Old 07-02-2016, 12:13 PM
It may be possible that oil is getting in the air filter and then the air turbulence caused from riding may work the oil around to the front of the cylinder.
It doesn't look as if the cylinder base gasket is leaking and it is hard to tell if the rocker box or rocker cover gasket is leaking.
Just for the heck of it pull the air filter and see if there is oil in it.
RGKen likes this.
post #5 of 11 (permalink) Old 07-02-2016, 05:02 PM
Desertwndrr's Avatar
I'm not seeing any wetness running down the front of the motor. I have a hard time with the idea that it's coming through the side of the jug. I'm with Ironmark. Most likely coming from the air filter and turbulence is pushing it there. Don't fill your oil over the midway point on the stick and that should help.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #6 of 11 (permalink) Old 07-03-2016, 08:30 AM Thread Starter
Bigmunkey's Avatar
There is some oil in the breather. I did only fill it to the half way point on the dipstick but I'm still getting some oil out of the breather.
post #7 of 11 (permalink) Old 07-05-2016, 08:02 AM
Looks like heavy application of S1 engine brightener, and then dirt sticking to it.
rg113 is offline
post #8 of 11 (permalink) Old 07-08-2016, 06:06 AM
Air turbulence around the engine, will in fact cause oils to migrate in what appears to be in a very odd fashion on occasion.
Scott
Hillsidecycle.com is offline
post #9 of 11 (permalink) Old 08-22-2016, 09:10 PM
crewchief25h's Avatar
I had a cylinder crack between the fins and leak oil from the drain passage exactly where yours is leaking.
crewchief25h is offline
post #10 of 11 (permalink) Old 08-23-2016, 07:02 AM
Good money, that this is it.
Scott
Oil seeping at 17k miles Ammo2 Engine Related 2 03-15-2015 10:48 AM
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 03:46 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 01:07 PM
Big Sucker seeping.. bikerglasses Intake and Exhaust 9 10-18-2013 08:24 PM
