Who's Running a 57H? - Road Glide Forums
post #1 of 11 (permalink) Old 01-12-2013, 06:10 PM Thread Starter
SIG556's Avatar
I bought one, but its going to be a couple months before it goes in. Looking for feedback on this cam.
Thanks
Ron
Back In Black!
SIG556 is offline
post #2 of 11 (permalink) Old 01-12-2013, 09:35 PM
MyGlide's Avatar
Not much feedback on these cams yet, but the few dyno sheets I've seen posted on a couple of the other forums have looked very impressive. I'm deciding between these and the new Kury tc24d cams coming out soon.
2018 KTM Super Duke R
MyGlide is offline
post #3 of 11 (permalink) Old 01-13-2013, 08:28 AM
prodrag1320
Guest
Posts: n/a
we`ve used the 57 on a couple builds.set them up @ 10.25-1
post #4 of 11 (permalink) Old 01-15-2013, 10:03 PM Thread Starter
SIG556's Avatar
What did you think?
Back In Black!
SIG556 is offline
post #5 of 11 (permalink) Old 01-16-2013, 06:11 AM
18/38 100 236 270 .560 lift tdc .184
46/14 106 240 274. 560 lift tdc .153
Andrews 57 specs.
Here is a dyno sheet link with Andrews 57 cam 106 S&S and Dragula pipe.
I did not build motor or tune... Different shop.....
DragoBikeWorks is offline
post #6 of 11 (permalink) Old 01-17-2013, 07:55 AM
prodrag1320
Guest
Posts: n/a
Originally Posted by SIG556 View Post
What did you think?
customers like them,good low end & carries up into the RPM band.will post dyno chart when they dyno bikes (both are breaking in before dyno`ing)
post #7 of 11 (permalink) Old 01-17-2013, 09:18 AM
tdkkart's Avatar
The 57h is a higher lift version(.560" vs .510") of a 37H so it should perform the same while being able to hold a bit more power on the top end.
I've used the 37 in 95" motors in both my past bikes, WideGlide and Ultra Classic, and was very happy with it. Pulls very well through the gears all the way to 6000 rpm or so. In carb'd applications it can be a bit pipe sensitive, leaving a hole in the power at 60mph cruise speeds. I'm certain this could be tuned out with EFI. Was especially bad with an early V&H Pro Pipe.
I've got an SE204 in my bike now, primarily because it's basically a 37 advanced 4* which was something I always wanted to try when I was running the 37. It works just as theory says it should, more bottom end, but is all done by 5500rpm. The 204 works well with the 6 speed gear box.
So, put the 57 in, I suspect you'll be happy with it. If you find you want more bottom end the fix is as easy as putting in a 4* advance sprocket.
tdkkart is offline
post #8 of 11 (permalink) Old 04-19-2013, 01:35 PM
spokanebagfan's Avatar
Has anyone put htis cam in yet, and if so what do you think? Just ordered mine.
spokanebagfan is offline
post #9 of 11 (permalink) Old 04-19-2013, 06:08 PM
Bump back to the top to see who is running this cam and their thoughts.
post #10 of 11 (permalink) Old 04-25-2013, 09:30 AM
verticalrich's Avatar
57
I just finished a 57 install on my bike, love it search for my user youll find the post
2012 FLTRU SE A/C, Andrews 57h, Dragula 2-1, Khrome Werks street sweeper 2+2, Dyno Jet Power Vision with auto tune pro
verticalrich is offline
2013 RG PV Map needed for 57H Cams Deadstroke Map Section 18 05-23-2016 09:57 PM
Andrews 57H Cams-What pipes are you running? LM1976 Intake and Exhaust 7 05-11-2014 07:00 PM
2011 rgu true duals 57h need PCv map gibrj Map Section 1 09-02-2013 10:18 AM
Andrews 57H ShitHouseRat Engine Related 56 08-12-2013 09:29 PM
Just wondering who running radial tires and who is running bias. Pros and cons please scsharp2260 Wheels and Tires 8 08-11-2013 08:20 AM
