Engine noisy at initial startup after cam install - Road Glide Forums
 2Likes
  • 1 Post By jeff338wm
  • 1 Post By Hillsidecycle.com
post #1 of 7 (permalink) Old 07-11-2016, 09:31 PM Thread Starter
warbird458's Avatar
I installed a set of Andrews 54 cams, and S&S premium lifters in my 15 RGS. I pulled the spark plugs, and spun the engine with the starter a little, in the hopes of pumping up some oil pressure for the initial startup. When I hit the starter, it sounded like I had spun a rod, so I shut down immediately. I waited a minute, hit the starter again, this time it was quieter. I assume that there was no oil, or pressure in the pump. For the first 5 or 10 minutes of running the engine there was top end noise, sounding like the lifters were not pumping up, which steadily decreased, until it quit making noise.It appears to sound normal to me now. Is this normal when doing a cam install? Should I worry about possible damage? This was my first cam install, so I am a little uncertain.
Roger
"Champagne Taste, on a Beer budget."
warbird458 is offline
post #2 of 7 (permalink) Old 07-11-2016, 09:54 PM
tdkkart's Avatar
Normal for a new cam install, takes a bit for the lifters to bleed out. As long as it's quiet and shows normal oil pressure, LET 'ER RIP!!!
tdkkart is offline
post #3 of 7 (permalink) Old 07-11-2016, 10:08 PM
Hullhorr's Avatar
I think your fine. New install requires a short time for oil to circulate into the new parts. If you continue to hear noise then maybe report back. Keep in mind new cams with a higher lift might produce a little more noise than stock.
2009 FLTR MOP
Hullhorr is offline
post #4 of 7 (permalink) Old 07-11-2016, 10:31 PM
jeff338wm's Avatar
Check your push rod adjustment
Roger
When I did my install I had a lifter hang on me at start up. I called S&S and they sent a replacement set next day air. Put them in and no issue after that. Lifters don't take 5 to 10 minutes to pump up. Also, next time I suggest to pump them up before you install them.
Smarty likes this.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #5 of 7 (permalink) Old 07-11-2016, 10:58 PM
Smarty's Avatar
I'm sure you did use assembly lube liberally on the new Torrington inner cam bearings, on the cam plate cam surface, on the lobes themselves, and pumped the lifters full of oil. Doing this prevents damage to the metal on metal surfaces before oil is flowing. Good luck, I'm sure everything will be fine.
2016 RGS Black Quartz
Smarty is offline
post #6 of 7 (permalink) Old 07-12-2016, 06:20 AM
Very normal.
Scott
Smarty likes this.
Hillsidecycle.com is offline
post #7 of 7 (permalink) Old 07-12-2016, 11:50 AM Thread Starter
warbird458's Avatar
Thanks All for the feedback. Unfortunately, I did not pump up the lifters, if that was in the service manual, I must have overlooked it. Everything sounds ok, just sent me into a panic at first.
Wood WM8-222 cam initial review Cagey Engine Related 12 02-28-2018 04:42 PM
Initial Sputtering on Start Up After Auto Tuning w PV JDisMe ECM/Fuel Management systems 13 06-28-2017 03:07 PM
Another Noisy Twin Cam Fix tdkkart Engine Related 3 10-06-2015 07:14 AM
Engine noise after cam install? Brianu1 Engine Related 1 09-03-2015 12:38 PM
Bang on startup nightglider Troubleshooting for Road Glides 17 01-31-2012 09:10 AM
