Does the 57H cam need higher compression on 103? - Road Glide Forums
 7Likes
post #1 of 21 (permalink) Old 07-23-2016, 08:42 AM Thread Starter
cookie114's Avatar
Doing some research on a cam choice and the 57h seems hard to beat for my riding style and setup on my engine which is just a TTS and stage 1. Ive read some post saying that the pre-Rushmore 103 engines could use a little more compression for this cam... anyone with experience with NON-Rushmore 103 that can add some input?
2013 FLTRX, stage 1 w/vance and hine power duals and rinehart slipons, TTS mastertune and some other odds and ins. Long ways to go
cookie114 is offline
post #2 of 21 (permalink) Old 07-23-2016, 08:54 AM
eddienelson's Avatar
Lots of guys running them with stock compression and loving them. I did the .030 head gasket when I did mine. 98hp and 111 tq at 95 degrees and 55% humidity. On a cooler less humid day it's 100 hp or better. So far I'm lovin it.
madmat likes this.
eddienelson is offline
post #3 of 21 (permalink) Old 07-23-2016, 09:41 AM Thread Starter
cookie114's Avatar
So changing out the head gasket gets the compression up... What does it put the compression at roughly? Also, does the cam start pulling pretty early? I ride pretty aggressive so not to worried about pulling super low rpms because im only there for a split second
post #4 of 21 (permalink) Old 07-23-2016, 11:00 AM
The factory head gasket is .045 thick and when you put the .030 head gasket on it bumps the compression up from 9.9 to 10.1:1. Factory compression is 9.7:1 so your raising it much. There is no doubt it pulls hard to 100 ish mph and I honestly don't know where it falls off past that. I also like to ride hard and so far I am very pleased and not in any way disappointed. It cruises really nice and very drivable around town but rock and rolls when on the throttle.
I was in a really big hurry to get home last week from North Dallas to central Louisiana about 350 miles. I rode from 80 to 100 mph the whole way with no problem. I also got 35 mpg considering I drove it like I stole it.
cookie114 likes this.
post #5 of 21 (permalink) Old 07-23-2016, 11:02 AM
Factory is 9.7. The head gasket will raise it between 9.9 to 10.1:1. Sorry I'm trying to multi task and I'm also semi retarded.
post #6 of 21 (permalink) Old 07-23-2016, 11:21 AM
Cat Mech's Avatar
I have the 57H cams with stock compression. Mine pulls good at least to 120 mph. I have a high flow intake and exhaust with a Thundermax tuner. Cams work great. Cams com on about 2400 rpm.
Cat Mech is offline
post #7 of 21 (permalink) Old 07-23-2016, 12:56 PM
GusEmery's Avatar
Send a message via Skype™ to GusEmery
Not to hi-jack this thread, however is the 96ci (2009) setup the same way as for compression and gasket size???
-G
P.S. I just installed 48h's and they pull from about 2k -> redline! Super strong pulls!
GusEmery is offline
post #8 of 21 (permalink) Old 07-23-2016, 02:21 PM
jeff338wm's Avatar
The .030" head gaskets make quite a difference surprisingly. One of the guys just added them with no other changes and should have dyno numbers before and after (once we return from Alberta).
Smarty and cookie114 like this.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #9 of 21 (permalink) Old 07-23-2016, 03:33 PM
Please post them when you get them. Y'all have fun and be safe.
Eddie
post #10 of 21 (permalink) Old 07-23-2016, 06:55 PM
ERod62's Avatar
Same numbers no gasket change just cams and push rods. Don't think worth the star work and expense. Actually Doc's performance tuned and recommend othe pipe and will gain couple numbers. Am running V&H HiOutput love the low rumble sound like muscle cars something have to give. Also say will be much better on the low end but this cam kicks in about 2400 rpm so am please. Fits how I ride.
Very good match for the stock 103
ERod62 is offline
High compression 103 13glidespoked Engine Related 18 09-22-2018 07:44 PM
103 57H Fuel Moto Level B 10.1-1 comp S&S 2-1-2 headpipe, Hitman muffs Darreldanger Dyno Results 3 10-04-2017 06:58 AM
103, 57h, Fuel Moto Level B 10.1-1 comp S&S 2-1-2 head pipe, hitman 4.5 muffs, powerv Darreldanger Dyno Results 6 08-22-2017 08:22 PM
103" Roadglide Motor Andrews 57H cams BigB64 Parts for Sale 11 02-04-2016 11:01 PM
Harley's new direction - Higher quality or just Higher Profits? Uncle Fuzzy *General Road Glide Discussions/Pictures 25 04-20-2012 07:29 AM
