120ST Upgrades - Road Glide Forums
post #1 of 2 (permalink) Old 07-27-2016, 05:55 PM Thread Starter
Khaotic's Avatar
120ST Upgrades
I have a 120ST, if I cam up to a TM 662-2 or TW408-6 do I need to change valve springs? I plan changing lifters to S&S and most likely a S&S or P3R flywheel. Also can I use a cometic .03 gasket to get compression bump? Would that net 10.8:1 from the stock 10.5:1?
2016 FLTRXS 120ST, SE Elite Heavy Breather, D&D Boss Boarzilla, Bandit Sportsman Clutch, Factory47 16" Malo and Arc Audio MPAC 6.
Khaotic is offline
post #2 of 2 (permalink) Old 07-28-2016, 06:40 AM
When leaning in the direction of using the spring to it's maximum lift prior to coil bind, collar to seal contact, etc, it is always best to check.
As far as the gasket, a tight sqiush band will create more turbulence in the chamber, and control spark knock as well, but you will not know what gasket to use prior to checking deck height, chamber volume.
Check twice, cut once.
Scott
Hillsidecycle.com is offline
2015 RGS with 120ST sammis Dyno Results 47 03-18-2016 01:35 AM
120ST D&D Biarzilla RGKen Dyno Results 46 01-04-2016 07:59 AM
Picked up a 15 RGS with a 120ST Spazz New Members Welcome Area 29 08-14-2015 09:10 AM
120st groupw *General Road Glide Discussions/Pictures 20 02-02-2015 11:17 AM
New 120ST Motor Nevadasun Engine Related 1 01-31-2015 11:16 PM
