Aftermarket Starters - Road Glide Forums
post #1 of 15 (permalink) Old 08-10-2016, 03:21 PM Thread Starter
JohnnyIce's Avatar
I am looking at a $500+ dollar bill if I get a new Harley starter and let the dealership put it in. What are the alternatives? I think I can put one in, just not sure what and what I could get a refurbished one for less than $200. Any ideas?
Johnny Ice
2018 Road Glide Special. 114CI; Vance & Hines Crossover Headers; TPS Exhaust with Zombie Baffles;
JohnnyIce is offline
post #2 of 15 (permalink) Old 08-10-2016, 04:15 PM
direwolf's Avatar
Last starter I put in was from ultima products, got it through bikers choice for under $200 I think. Also went larger KW as it was going on my 107 which ate Harley starters. I would have to check paperwork for actual part #
...2009 SERG...Last of the Hand Built's..
direwolf is online now
post #3 of 15 (permalink) Old 08-10-2016, 05:56 PM
Q-Hog's Avatar
I have a couple friends that replaced their starters for one that has a push in lever and it starts the bike up. I can check on that for you.
Q-Hog is offline
post #4 of 15 (permalink) Old 08-10-2016, 09:07 PM
FDR's RGC's Avatar
Find a rebuilder in your area. Right around $50.00
FDR's RGC is online now
post #5 of 15 (permalink) Old 08-10-2016, 09:25 PM
TroyAK's Avatar
I paid $180 for a rebuild here(1.2kw).... It failed after 629 miles. Got it rebuilt for free then it completely grenaded after 650 miles.
I but the bullet and picked up the HO starter that HD sells. So far so good.
Your results may vary.
2010 RGC with stage 2 and some things
TroyAK is offline
post #6 of 15 (permalink) Old 08-12-2016, 11:51 AM Thread Starter
JohnnyIce's Avatar
I can get a 1.4W aftermarket for about $157 or a 1.6W for about $180. Stock for a 2013 Road Glide Custom is a 1.2W. I checked Ultima, but they only make starter up to 2005. They Harley changed the starters in 2006.
I put a 110 CI engine in, so thinking about the 1.4W aftermarket. CVOs come with a 1.4W. I found a 2.4W for about a grand, but why would I want to. No sure if the 1.2W is worth rebuilding, except to sell.
Johnny Ice
post #7 of 15 (permalink) Old 08-12-2016, 02:23 PM
GusEmery's Avatar
Send a message via Skype™ to GusEmery
This is on a totally different engine; however I replaced my EVO starter for under $200 with a 1.4KW starter. Works AMAZING.. However, it was REALLY REALLY easy to put in. Infact I just had to remove it to work on my inner primary seal the other day. Came out in like 20 seconds.
-G
GusEmery is offline
post #8 of 15 (permalink) Old 08-12-2016, 03:55 PM
Stoic Joker's Avatar
I pulled mine (10 RGC) to replace the starter clutch, wasn't any big deal ... half an hour maybe.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is online now
post #9 of 15 (permalink) Old 08-12-2016, 05:27 PM
had a friend replace his starter with one off a honda (or was it toyota) small car. Point is, these twincam starters are used elsewhere than just HD. Find out what the automotive replacement is for it and save a ton.
(to the naysayers, I saw both starters on the benchtop and you couldn't tell the difference between the two.)
HoustonUltra is offline
post #10 of 15 (permalink) Old 08-12-2016, 05:34 PM
lil chief's Avatar
You are correct. Both are Nippendenso starters, and I believe the starter used on Toyotas are the same exact ones Harley uses. I don't recall the Toyota part # right off hand, but if you google a cross reference of some sort it should be found quite easily. Or, try searching Toyota starter for Harley or something to that effect.
Lil Chief
lil chief is online now
Tags
replacement , starter
Aftermarket Stereo Install ?'s jbrawkus Aftermarket Accessories 25 08-26-2010 07:13 PM
Do aftermarket systems void warranty? Mink ECM/Fuel Management systems 30 08-26-2010 09:49 AM
Aftermarket Fuel Additives brightonrider *General Road Glide Discussions/Pictures 6 07-30-2010 10:29 PM
Aftermarket Questions CustomGlide *General Road Glide Discussions/Pictures 10 04-25-2010 12:10 AM
Aftermarket Stereo Intaller San Antonio Area jbrawkus *General Road Glide Discussions/Pictures 0 03-02-2010 10:20 AM
