New primary rattle - Road Glide Forums
post #1 of 23 (permalink) Old 01-22-2013, 08:27 PM Thread Starter
dwighop's Avatar
New primary rattle
I'm sure it's on the forum somewhere but I can't seem to find it. After riding about 70 miles today when I stopped at a light in gear with clutch pulled in there was a terrifying noise coming from the primary. Same thing at the next stop but dropped into neutral let go of the clutch and nothing. Any experience or guesses before I haul it to the shop? 2011 RGU. Thanks.
dwighop is offline
post #2 of 23 (permalink) Old 01-22-2013, 10:07 PM
rageglide's Avatar
Some people thought my Woods TW-6H made terrifying noises... me not so much. Define terrifying. Rattle? Screetch? Grinding?
rageglide is offline
post #3 of 23 (permalink) Old 01-22-2013, 10:09 PM
caboverbob's Avatar
Shifter shaft ?
My shifter shaft rattles and makes noise, just needs to be greased and adjusted. Could this be what you're hearing ?
caboverbob is offline
post #4 of 23 (permalink) Old 01-22-2013, 10:11 PM
The nut on your engine compensator is loose. Take into the dealer for repairs.
post #5 of 23 (permalink) Old 01-22-2013, 10:27 PM
rageglide's Avatar
But it's quiet when in neutral and clutch out. I'd expect a loose comp nut to make same noise either way, then again haven't really thought of that before.
post #6 of 23 (permalink) Old 01-22-2013, 11:41 PM
Jay2Beers's Avatar
Haul it in. ASAP I had terrifying noise and it turned out to be the 6th gear (bearings pitted).
QUOTE=dwighop;373448]I'm sure it's on the forum somewhere but I can't seem to find it. After riding about 70 miles today when I stopped at a light in gear with clutch pulled in there was a terrifying noise coming from the primary. Same thing at the next stop but dropped into neutral let go of the clutch and nothing. Any experience or guesses before I haul it to the shop? 2011 RGU. Thanks.[/QUOTE]
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #7 of 23 (permalink) Old 01-23-2013, 02:21 AM
Taccone's Avatar
Saaaaaaame noise came from my new 2012 fltrx with about 1100 miles on the clock. It ended up being the bolt that holds the cam plate in place. I actually had it let go while riding to the dealer, dealer said "ride it here, if it breaks it's under warr. and we'll come get you" so about 2 mi. from my house the motor seized. Caused minor damage to anything really, only destroyed the timing cover, replaced under warr. along withe new cam's and pushrods under warr. too! So I went with the SE254E cam's got them installed for free too with adj. pushrods, couldn't be happier, happend becuas MOCO didn't put thread locker on my cam plate bolt. I don't mind, worked out great in the long run. With my setup I run away from stock 103's easily! and CVO's lol
Taccone is offline
post #8 of 23 (permalink) Old 01-23-2013, 07:31 AM Thread Starter
dwighop's Avatar
New primary rattle
Definitely on the primary side. The shifter arm is a noise I've gotten used to when I swapped it out. I had read about the compensator nut and was leaning that way. First thought the radio was going freaky. Then started looking for parts falling off. Sounds like a stealer trip.
dwighop is offline
post #9 of 23 (permalink) Old 01-23-2013, 07:57 AM
If my memory serves me right you might have the old style comp.
And it will look like this after awhile.
DragoBikeWorks is offline
post #10 of 23 (permalink) Old 01-23-2013, 09:35 AM
Rkfltrx's Avatar
Hummm? My 2012 rattles when it is in neutral. Not bad, but you can hear it.
SOLD:
2012 FLTRX Denim Black,Stock head pipe with Cat removed w/ Jackpot 4" black slash up slip-ons. power vision, Fuel Moto pro billet A/C, Woods TW-222's, 12" Klock Werks . Sanchos Wings. Khrome werks 2+2 Handlebars.
Rkfltrx is offline
Can you get Sedona Orange in a rattle can? Gadgetech *General Road Glide Discussions/Pictures 18 01-10-2017 12:34 AM
Rattle ohd24 Tech Area 2 01-21-2012 03:49 PM
2011 clacking/rattle at 2200 + RPM Passed Troubleshooting for Road Glides 22 07-30-2011 11:23 PM
Scarlet Red Rattle Can Sancho Do-IT-Yourself 12 11-29-2010 10:12 PM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 04:15 PM
