Stage III upgrade from 107 to 114 available - Road Glide Forums
 14Likes
post #1 of 27 (permalink) Old 08-14-2016, 07:44 PM Thread Starter
Ohiobellboy's Avatar
At least the pix are there. If you try to click on the link, it says the parts are no longer available.
Harley-Davidson Search
RGKen, Wmoor004 and thealaskan like this.
A.K.A OBB
Ohiobellboy is offline
post #2 of 27 (permalink) Old 08-14-2016, 08:12 PM
RGKen's Avatar
Looks like it's becoming reality.
2018 FLTRXS
RGKen is offline
post #3 of 27 (permalink) Old 08-14-2016, 08:13 PM
RGKen's Avatar
Link just worked for me!
2018 FLTRXS
RGKen is offline
post #4 of 27 (permalink) Old 08-14-2016, 08:19 PM Thread Starter
You can get to that page, You can't get to the individual parts or kits off that page.
RGKen likes this.
A.K.A OBB
post #5 of 27 (permalink) Old 08-15-2016, 01:45 PM
Chrisg81983's Avatar
Well for once could all the hype be correct
Chrisg81983 is offline
post #6 of 27 (permalink) Old 11-27-2016, 08:32 PM
bikepsych's Avatar
Has anyone gone to Stage III on the M8 engine yet? The claimed HP & TQ numbers are impressive. But what does that do to the MPGs?
Bikepsych
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
post #7 of 27 (permalink) Old 11-28-2016, 06:47 AM
eddienelson's Avatar
My neighbor just had the dealer put one on his 2017. I don't think he has 100 miles on it. The dealer flashed a tune on it and said once he's done his 1000 mile service they will dyno it.
2016 RG Custom Vivid Black
eddienelson is offline
post #8 of 27 (permalink) Old 11-28-2016, 07:46 AM
Send a message via Skype™ to HUGE_Tom
I talked to the dealer about this kit over the weekend. The kit is $2,000 and another $1.000-1200 in labor. They only did 1 so far. As far as the numbers it is still hard to compare it to the 103 or 110. Since none of the exhaust companies have come out with their full exhausts yet without the cat, we still really don't know what kind of numbers the M8 107 will do with a full exhaust, AC, and aftermarket cam; so we still can't really compare it to the 103 yet. Looking forward to the 2-into-1 full exhausts from FuelMoto, Dragos, and Rush Racing. Doing dyno runs with the cat in place is a waste of time and money right now.
michaelgrudgings likes this.
HUGE_Tom is offline
post #9 of 27 (permalink) Old 11-28-2016, 09:49 PM
[QUOTE=bikepsych;3713570]Has anyone gone to Stage III on the M8 engine yet? The claimed HP & TQ nimpressive. But what does that do to the MPGs?
Bikepsych[/
Any one worried about gas mileage, should leave their bike stock. When you modify your motor, you usually don't worry about the gas mileage.
Wmoor004 and twowheeladdict like this.
00se1550 is offline
post #10 of 27 (permalink) Old 11-28-2016, 11:14 PM
bikepsych's Avatar
I disagree. I think you can get both. If you tune an engine right, you can get both a lot of power AND good efficiency. In the long run, isn't an engine with better efficiency going to make more power? If it's wasting fuel, its not running efficiently. I've got a 103 build with 109HP and 116tq and getting 45mpg at 70-80mph. On a recent run to Colorado it got up to 52 at high elevation. The bigger engine is naturally going to suck more fuel, but it shouldn't kill the fuel mileage that much. I've heard that the stock 107's are getting around 50 on the highway, so a drop down to around 40-43 should be realistic with the right tune.
Wmoor004 and eddienelson like this.
114" M8 stage III cylinders/pistons etc... mtharston Parts for Sale 0 05-02-2018 09:58 PM
Map for Stage 3 - 114 kit Wmoor004 Map Section 7 03-16-2018 10:34 PM
2017 Special 107 to 114 wow dshudson *General Road Glide Discussions/Pictures 44 01-26-2018 09:38 PM
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 11:02 AM
Stage III 103 to 110 or Stage III Performance Upgrade? javal2001 Engine Related 0 06-04-2017 03:27 PM
