"Pieces" fell - cases needs to be cracked - Road Glide Forums
post #1 of 55 (permalink) Old 01-24-2013, 11:48 AM Thread Starter
DOOFUS's Avatar
Service just called me - while doing my cam upgrade:
- "pieces" came off the cam bearing
- They "think" they have found 90% of the pieces
- but now must crack the cases "to be sure"
My first question was:
I'M NOT BEING CHARGED FOR THIS EXTRA WORK RIGHT?
ANSWER:
"Oh no, don't worry."
So, you gear heads - does this sound legit to you?
DOOF
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #2 of 55 (permalink) Old 01-24-2013, 11:57 AM
Harleyagain's Avatar
If they broke it, they need to fix it at no charge to you! I would not except being charged for their doing.....
Bob
Harleyagain is offline
post #3 of 55 (permalink) Old 01-24-2013, 11:59 AM Thread Starter
DOOFUS's Avatar
Yes - under warranty - but ya know how that goes.
Yes - thats what lead tech said - "broke on the way out".
Possible or am I getting a "story" to cover another issue?
THNX, DOOF
Originally Posted by Harleyagain View Post
If they do charge you, they have to call you and let you know! Hopefully your bike is still under warranty, if so no worries, ya right lol....
Talk about timing on getting new cams installed. Makes you wonder how long your bearing was broken. Wonder if they broke em taking them out???
IBA# 22419
120,000k+ HD Miles
DOOFUS is offline
post #4 of 55 (permalink) Old 01-24-2013, 12:06 PM
THNX, DOOF
I think they are being honest otherwise they didn't have to call you. Makes you wonder about those stock bearings tho!!
Bob
post #5 of 55 (permalink) Old 01-24-2013, 12:15 PM
Triplej's Avatar
More than likely the tech broke the plastic cage that holds the needle bearings in place when trying to install the cam bearing puller. Once that happens the needles can easily fall down into areas that cannot be reached without splitting the cases.
Sucks and I hope they indeed find all the pieces.
Triplej is offline
post #6 of 55 (permalink) Old 01-24-2013, 12:20 PM
I really did not need to hear that now!! Whew!!!
Bob
post #7 of 55 (permalink) Old 01-24-2013, 12:22 PM
598Malibu's Avatar
Hopefully they mark that on your work order. Keep a copy on case you have any future related problems.
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #8 of 55 (permalink) Old 01-24-2013, 12:51 PM
Do you have this bike 103" already? Or 107" they got to pull cylinders might be time for high comp pistons and such. On their dime. I say upgrade. Lol
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #9 of 55 (permalink) Old 01-24-2013, 01:15 PM
+1, if they have to split the case, I would definetly inquire about improving the crank.....
post #10 of 55 (permalink) Old 01-24-2013, 01:36 PM
Fire-Medic's Avatar
As Piesik and Dbell stated, if they're splitting the cases on their dime, and it was "my" bike, then it's the perfect time to upgrade if you ever think you will. Because you just have to pay for parts, the labor will be on them because of the screw up. Time for a trued/welded crank, timken bearing, and 107 or bigger.........
Will save you a considerable amount of cash. The parts to go bigger cubes have to go on same as the stock ones do.
Just my $0.02
Fire-Medic is offline
Well today I fell off the wagon...Ordered 124" piesik650 Engine Related 92 04-29-2013 01:20 PM
New Cases CR3999 *General Road Glide Discussions/Pictures 10 04-25-2013 11:43 PM
09 strret glide engine cases rio1012006 Engine Related 1 09-04-2011 02:34 PM
Top cases Glideman07 Aftermarket Accessories 1 09-03-2011 12:26 AM
New cases pte359 *General Road Glide Discussions/Pictures 0 07-02-2011 12:05 PM
