Valve train noise thread - Road Glide Forums
post #1 of 13 (permalink) Old 08-15-2016, 07:48 PM Thread Starter
sfcusaret2004's Avatar
Not sure where I saw the thread but the discussion was about a kit to quiet the valve train/rocker arms due to sloppy tolerances. If I remember correctly the kit contained some brass bushings that tightened up the rocker arm shafts and protected them from push rod damage(?) anyone have a clue about this? I'm getting tired of listening to my topend on my '13 ultra and in the words of Ned Stark, "Winter is coming!" need a project.
sfcusaret2004 is offline
post #2 of 13 (permalink) Old 08-15-2016, 08:09 PM
kouack's Avatar
Rocker locker
Envoyé de mon GT-P5113 en utilisant Tapatalk
kouack is offline
post #3 of 13 (permalink) Old 08-18-2016, 06:23 AM
Those help, but a lot to be said for a good set of adjustable pushrods along with a good set of lifters. S&S is the brand we reach for here.
Scott
Hillsidecycle.com is offline
post #4 of 13 (permalink) Old 08-23-2016, 12:20 PM
FLtroll's Avatar
Just had my lifters upgraded and the Rocker Lockers installed, and WOW, what a difference! I am shocked at how refined my engine is now. Went ahead and did the upgraded cam plate and high flow oil pump too. Wish I had done this years ago.
2011 Road Glide Ultra. Merlot Sunglo
FLtroll is offline
post #5 of 13 (permalink) Old 08-24-2016, 07:27 AM
Proper lifter pre-load, via an adjustable pushrod, to maintain proper lifter load at full thermal expansion, along with a good quality lifter, will cure about 7/8 of most valvetrain-related noises, in these engines.
Scott
post #6 of 13 (permalink) Old 08-24-2016, 10:24 AM
tdkkart's Avatar
The Rocker Lockers do indeed reduce the noise, but only from one of the sources, there are a few left.
tdkkart is offline
post #7 of 13 (permalink) Old 08-24-2016, 10:41 AM
Clutch1's Avatar
Not to hijack your thread but I have an 04 with a stock 88ci with a lot of valve train noise. Which adjustable pushrods do you recommend?
Clutch1 is offline
post #8 of 13 (permalink) Old 08-25-2016, 06:20 AM
See post #3.
post #9 of 13 (permalink) Old 08-25-2016, 06:58 AM
Scott; isn't there a locktite product you guys use on rocker arm shafts?
dozer23 is offline
post #10 of 13 (permalink) Old 08-26-2016, 12:27 AM
JacktheBagger's Avatar
Anytime you need aftermarket engine components , S&S is the first choice , haven't let me down in 45 years ..
2011 Ultra
JacktheBagger is offline
Compensator or valve train noise???? StGhost Engine Related 19 08-29-2018 10:16 PM
Valve train noise 1st Sgt Engine Related 11 01-15-2018 05:12 PM
Possible valve train noise rlaf75 Troubleshooting for Road Glides 20 05-24-2016 10:42 PM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Increase in Valve train noise when engine cold StriderJim Troubleshooting for Road Glides 8 10-07-2012 10:21 AM
