Stuck K&N oil filter - Road Glide Forums
post #1 of 26 (permalink) Old 01-25-2013, 05:36 PM Thread Starter
Sethjamto's Avatar
This is killing me. A simple oil change over a couple beers...the nut (17mm) on the end of my K&N oil filter stripped and broke off. Mr strap wrench won't get in there and the HD oil filter wrench doesn't fit the K&N. I don't want to do the screwdriver trick but will if I have to. Any other ideas? Are K&Ns thick enough to do the screwdriver trick? It's friggin 72 degrees...I don't have time for this crap.
2015 Denim Black FLTRXS
14" Vindikta's - Rinehart True Duals - SE Heavy Breather Elite - Screaming Eagle Pro Super Tuner - King Tour Pak - 85.45hp / 104.41tq
Sethjamto is offline
post #2 of 26 (permalink) Old 01-25-2013, 05:42 PM
reficul's Avatar
Screwdriver, make a mess and get it done.
2012 Shark Face
One day he is gonna answer
reficul is offline
post #3 of 26 (permalink) Old 01-25-2013, 05:48 PM
Ironrider's Avatar
go buy the plier type you can get it with that, youll bend the heck out of it butwho cares.
Ironrider
Ironrider is offline
post #4 of 26 (permalink) Old 01-25-2013, 05:52 PM
Triplej's Avatar
I agree, ur wasting precious ridin time
Triplej is offline
post #5 of 26 (permalink) Old 01-25-2013, 05:57 PM
JJSW1283's Avatar
Get a big enough pair of channel locks and squeeze down on the filter to make a flat spot on each side. Then can slowly loosen the filter a hair at a time. Been there done that.
JJSW1283 is offline
post #6 of 26 (permalink) Old 01-25-2013, 06:03 PM
Harleyagain's Avatar
Sadly I had to do that on my FJR, and it was a major pain!
Bob
Harleyagain is offline
post #7 of 26 (permalink) Old 01-25-2013, 06:15 PM
caboverbob's Avatar
Napa
I use K&N filters also, but the nut is useless IMO. I have a couple of strap wrenches from Napa auto parts that work great. Basically it is a piece of 1/2" square tubing about 3-1/2" long with a web strap on one end to go around the filter and you insert a 1/2" ratchet in the other end. They never fail. It also helps to have your engine at operating temp.
Peace
caboverbob is offline
post #8 of 26 (permalink) Old 01-25-2013, 11:05 PM Thread Starter
Sethjamto's Avatar
Well.... I went out for a few hours with friends to blow off steam. Got a metal strap wrench on the way home and just tried that. Even that is crushing the filter. This thing is really stuck on there. I'm afraid a screwdriver will just shred it and still not get it off. I'll mess with it in the morning.
post #9 of 26 (permalink) Old 01-25-2013, 11:09 PM
Eddiezero's Avatar
Re: Stuck K&N oil filter
When my old bike had that, i just jammed the screwdriver through it and that got it to turn:banghead:
Sent from my ASUS Transformer Pad TF300T using Motorcycle.com Free App
Never trade the thrills of living for the security of existence.
Eddiezero is offline
post #10 of 26 (permalink) Old 01-25-2013, 11:09 PM
caboverbob's Avatar
I've had filters crush before using strap wrench that I suggested earlier, but eventually they will come. I wouldn't use the screwdriver, if it doesn't turn the filter it will certainly tear the shit out of it and then you can't use any type of wrench at all on it.
Make sure motor is at operating temperature, it will make a difference.
Good luck
HD Oil Filter stuck 1st Sgt Engine Related 25 03-27-2018 09:52 PM
K&N Filter vs.HD Oil Filter RRHartzler Fluids and Lubricants 49 10-22-2016 08:00 PM
Ignition switch Stuck & i mean stuck.... maddmoe Troubleshooting for Road Glides 11 07-08-2016 06:22 AM
oil smell & oil in air filter fat boy ultra Troubleshooting for Road Glides 6 04-11-2013 11:04 AM
Need Help! Selecting Oil, Oil Filter & Air Filter Big Red 103 Do-IT-Yourself 5 06-06-2011 12:38 PM
