Oh Great Broken Crankshaft - Road Glide Forums
 5Likes
post #1 of 28 (permalink) Old 08-18-2016, 04:18 PM Thread Starter
Had some noise in the primary for awhile, whining or whirling, something like that. Took it to my Indy this morning and was informed a broken crankshaft. Got a quote to fix it and when it hit $1100 this, $1300 that, my ears closed off. Would appreciate any advice on what or what not to do. 2013 Road Glide 16,500 miles. Anything else to do while it's opened up and what parts to use?
2013 Road Glide Custom - Arlen Ness Big Sucker - 4" Jackpots - Dynojet Power Vision - Le Pera DLL SEAT - LRS MAKO 14" SHIELD
Pork Chop is offline
post #2 of 28 (permalink) Old 08-18-2016, 04:40 PM
lil chief's Avatar
Well, now would be the time to upgrade to an S&S crank, or a reman one from Darkhorse. Unless you look for a used motor or takeout motor. I saw a 2016 Road Glide motor on Craigslist the other day for like $2500, and I think they said it had like 16 miles on it, so there's options out there, just pick the one that fits your budget. Even if you do get a stock replacement crank, think about having it trued and welded by Darkhorse.
Lil Chief
G5Driver likes this.
lil chief is offline
post #3 of 28 (permalink) Old 08-18-2016, 05:51 PM
Nordic Berserker's Avatar
bigb64 on here sold his 2016 103" engine for $1800 I think it was last week, definitely look into a used or new takeoff before spending thousands on repair unless you upgrade crank & go the 117" route.
Nordic Berserker is offline
post #4 of 28 (permalink) Old 08-18-2016, 07:42 PM Thread Starter
Didn't think of a used engine and found one for $1699 with 15k on it. Might go that route and have some spare heads for later mods. Y'all think swapping engines would be a hair more frugal ? Haven't discussed that option with my Indy but will in the morning.
post #5 of 28 (permalink) Old 08-18-2016, 08:07 PM
lil chief's Avatar
I honestly think its a smarter move financially, as long as the new motor is in good shape. Probably cheaper in labor to just swap the motor too. As you said, there's gonna be some parts from the old motor that you can use in the future. You'll probably have less down time with just swapping the motor as well. If I were to purchase a used motor, I'd have your indy do a leak down test on it, and maybe bore scope the cylinders to see what the pistons and cylinders look like. Some dealerships have brand new take out motors sitting in the back room too. Some people upgrade right to a 120" before they even take delivery of their bikes. That might be another option.
Lil Chief
post #6 of 28 (permalink) Old 08-18-2016, 09:21 PM
bucketlisthd's Avatar
A Rushmore 103 HO would be a good way to go.
bucketlisthd is offline
post #7 of 28 (permalink) Old 08-18-2016, 09:22 PM
Bruce00's Avatar
There are low or no mile take out 103 motors available. If your not pressed for time, I wouldn't jump on the first motor you find. Take your time and find that gem out there.
Anyway, best of luck getting back in the wind
lil chief likes this.
Bikeless
2015 RoadGlide Special--RIP
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #8 of 28 (permalink) Old 08-19-2016, 05:29 AM
We just sent a 110" engine home yesterday with a client, after a 124" replacement/mods.
He is wanting to sell it.
Scott
Hillsidecycle.com is offline
post #9 of 28 (permalink) Old 08-19-2016, 06:02 AM
Desertwndrr's Avatar
You had a noise in the primary for "a while"? What exactly is broke? That doesn't sound like a crank. Crank would be bad vibration or a number of other things nut whirring in the primary doesn't sound right. Does it?
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #10 of 28 (permalink) Old 08-19-2016, 07:25 AM
mastergunnera8's Avatar
Agree...locally there are '16 motors with 0 miles for 2K to 4000 miles for 1600..they are out there...not sure of mississipi...then theres Hillsides customer..that may be interesting if youre into 110....personally I'd opt for the 103...
It is odd at 16K miles for a crankshaft to go?..geez...esertwndrr may have a point, maybe a second opinion...
Your ride is disassembled at the shop? Is the motor out What's the charge for the diagnosis? Best of luck, hope it all works out for you...
mastergunnera8 is offline
oh where oh where does this little plug go?? Kobrak Troubleshooting for Road Glides 4 01-05-2016 03:37 PM
Pressed crankshaft excessive runout! Biker Bill Engine Related 9 09-29-2015 01:01 PM
Crankshaft scissoring Darreldanger Engine Related 7 11-18-2014 07:36 AM
Broken Speaker Mounts DAK47 Audio 14 06-15-2014 08:25 PM
Crankshaft moving? Anyone had this? Busted1 *General Road Glide Discussions/Pictures 6 10-25-2013 07:30 PM
