Cam position sensor question - Road Glide Forums
post #1 of 9 (permalink) Old 01-27-2013, 03:10 PM Thread Starter
caboverbob's Avatar
So I have a 2001 RG w/Magnetti Marreli fuel injection. I am sending a bunch of parts out for powdercoating including the camchest cover. I have a service manual and it tells me that in order to remove the cam position sensor that I will have to do quite a bit of work to pull one of the harness' forward from the side panel and then remove wires from connector. This is a lot of work and I don't want to disturb parts of the wire harness that I don't need to. There are 3 wires running to this sensor and I am considering cutting them and placing a 3 position connector in line in order to splice them back together. Any words of wisdom here ?
Peace
caboverbob is offline
post #2 of 9 (permalink) Old 01-27-2013, 03:49 PM
tdkkart's Avatar
Peace
Are you sure the sensor is there?? Some of the '01s had them, some later ones did not, my '01 ultra classic did not.
I don't see any reason you can't splice in a connector as long as you do a decent job of it.
tdkkart is offline
post #3 of 9 (permalink) Old 01-27-2013, 04:07 PM Thread Starter
caboverbob's Avatar
Ya, sensor is definitely there. I just want to replace cam chest cover, but with wires running through it and no disconnect in sight, I may be forced to cut it and splice a connector back in.
post #4 of 9 (permalink) Old 01-27-2013, 06:30 PM
Bigtrev8xl's Avatar
That's how I done mine cut the cable, and soldered so the joint was in the cam chest.
I DON'T DO RUSHING!
Bigtrev8xl is offline
post #5 of 9 (permalink) Old 01-27-2013, 06:41 PM Thread Starter
caboverbob's Avatar
Thanks Bigtrev. My only reason for wanting to put a connector in line was that so if in the future I decide to change covers again or if sensor should happen to go ou it would make it easier.
Peace
post #6 of 9 (permalink) Old 01-28-2013, 04:58 AM
Bigtrev8xl's Avatar
Peace
Do you know of a connector that's easy to take apart, that will fit through the hole in the cam chest cover.
I DON'T DO RUSHING!
post #7 of 9 (permalink) Old 05-19-2013, 11:30 PM Thread Starter
caboverbob's Avatar
Peace
OK, not sure if anyone else has done the cut and splice on cam position sensor, but DON'T do it. I did it, I did a clean solder and heat shrink job, and now I am heading into replacing it with a new one that stretches through the main harness all the way to the right side cover, which is what I was trying to avoid in the first place. It seems as though I somehow changed the resistance in the wiring and that may be affecting the signal, therefore causing bike to run poorly and die frequently.
Peace
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
post #8 of 9 (permalink) Old 05-20-2013, 04:24 AM
Bigtrev8xl's Avatar
Peace
You must have done some thing wrong or I must have been very lucky then I've done it on 3 different bikes now,believe it or not soldering electric cables is quite common
Of course it is possible to remove the pins from the connector plug if you want to.
I DON'T DO RUSHING!
post #9 of 9 (permalink) Old 05-20-2013, 07:14 PM Thread Starter
caboverbob's Avatar
Remove the pins is what I shall do now. It could be that one of my solder connections is suspect, don't really know, but it was a very limited space to splice 3 wires and get them shrink wrapped correctly.
Peace
Build thread
(CKP) Crank Position Sensor error code............. maddmoe Engine Related 7 08-28-2016 12:29 AM
Throttle position sensor question AnCap Controls & Handlebars 0 09-18-2015 07:32 PM
Cam or not to cam! Tiz the question pipe3214 Engine Related 6 02-13-2015 03:59 PM
To Cam or Not To Cam is the Question? Cmathias Engine Related 29 07-11-2013 01:25 PM
Throttle Position Sensor GOSKERZ Troubleshooting for Road Glides 9 06-17-2012 09:03 AM
