16 RGU downshiftng problems - Road Glide Forums
 3Likes
post #1 of 17 (permalink) Old 09-02-2016, 08:43 AM Thread Starter
16 RGU 4000 miles. Noticed the bike not downshifting to 1st on occasion. Now can't downshift to 2nd or 3rd at times. 95% of the time it shifts perfect. Taking it back to dealer next week. Just thought I'd get some input here. Thanks in advance for the help.
NMRoadrunner is offline
post #2 of 17 (permalink) Old 09-02-2016, 05:04 PM
Chrisg81983's Avatar
When does it happen ? While moving or is it when you come to a complete stop before downshifting ? A lot of times if you come to a stop first then try to downshift you will have to double clutch it to get into first. I always downshift and give a little blip of the throttle [ rev match ] to avoid this common issue.
Chrisg81983 is offline
post #3 of 17 (permalink) Old 09-02-2016, 07:35 PM Thread Starter
This happens as I am gearing down as I slow down. I've tried up shifting then downshifting, rocking the clutch and even some four letter words. Can't find anything that helps. Lots of throttle and slipping the clutch gets me going again. At the next stop or turn it works fine.
post #4 of 17 (permalink) Old 09-02-2016, 08:12 PM
Where the fluids changes at 1k? If so to what?
2016 Cosmic Blue Pearl RGU
2002 883R Sportster
Kennyd is offline
post #5 of 17 (permalink) Old 09-02-2016, 09:17 PM Thread Starter
Had the dealer do the 1K. Don't think they changed the fluids. Even though my bike isn't in the recall the dealer is going to change fluids first. As irratic as the problems is I don't think the fluids will make any difference.
post #6 of 17 (permalink) Old 09-02-2016, 11:02 PM
MontyMoose's Avatar
There's currently a recall on several of the touring and softtail bikes for potential issues with the master cylinder:
Open Recalls
NHTSA Recall Campaign Number: 16V-471Recall Date Jul 08, 2016
Last UpdatedSep 02, 2016
Harley-Davidson has learned that the hydraulic clutch system with black master cylinder part numbers 36700049B, 36700056B, 36700146 and 36700186 on certain model year 2016 Touring and Softail model motorcycles may exhibit a condition in which it may lose the ability to generate enough lift to disengage the clutch after being parked for an extended period.
Model
2016 Road Glide Ultra
Safety Risk
If this condition remains undetected it could lead to a loss of control of the vehicle when started in gear or first shifted into gear after being parked for an extended period.
REMEDY
Owners of the affected motorcycles will be asked to arrange service with an authorized HarleyÂ*Davidson dealer, who will confirm that the motorcycle is covered by this recall. If covered, the dealer will inspect the clutch master cylinder for the presence of gas in the fluid. If there is gas in the fluid, thedealer will flush the clutch system with the recommended wash solution and rebuild the clutch master cylinder using the recall kit provided. This service will be provided at no charge to the customer.
We strongly urge you to take your motorcycle to your dealer to have the appropriate service performed as soon as possible. Should you choose to ride your motorcycle prior to this service, we urge you to be aware of this condition. Some product campaigns may have expired and you may have to pay for the service. Please see your local Harley-Davidson dealer for further details.
2016 CBP FLTRU w/Cobra Neighbor Haters & SE Stage 1 kit
The Best Marine is a Submarine. USS Los Angeles (SSN 688): The First and Finest ~ 2002-2006
MontyMoose is offline
post #7 of 17 (permalink) Old 09-03-2016, 07:16 AM
Changing all three fluids (engine oil, primary oil, and transmission oil) is required at the 1k service
Swomack likes this.
2002 883R Sportster
Kennyd is offline
post #8 of 17 (permalink) Old 09-03-2016, 08:10 AM Thread Starter
I was referring to brake fluid change. Sorry for the confusion.
post #9 of 17 (permalink) Old 09-03-2016, 08:12 AM Thread Starter
Clutch fluid change. Even more confusion.
post #10 of 17 (permalink) Old 09-03-2016, 08:13 AM
LOL, still early!
FYI you can edit your post's...
2002 883R Sportster
Kennyd is offline
15/16 inherant problems pismorider New Members Welcome Area 27 08-22-2019 09:51 PM
Harley brand apes for 16-16 -looking for pat numbers for extended wires/lines Steelerdude1 *General Road Glide Discussions/Pictures 2 10-17-2015 09:41 PM
180/65b/16 vs 200/60r/16 jaycallender Wheels and Tires 3 09-26-2014 11:40 AM
2012 RGU electrical problems PghCycle 24 *General Road Glide Discussions/Pictures 6 06-11-2012 06:30 PM
