cams? - Road Glide Forums
View Poll Results: What is the better cam for a 110 to 117 upgrade?
SE-295E 3 37.50%
SE-585 5 62.50%
Voters: 8. You may not vote on this poll
 2Likes
  • 1 Post By Hillsidecycle.com
  • 1 Post By 09 YELLOWBIRD
post #1 of 10 (permalink) Old 09-10-2016, 02:35 AM Thread Starter
cams?
So, I'm looking into upgrading my CVO 110CI to the 117CI. However, I noticed that the $2095 kit comes with SE-295E cams while the SE-585 cams are sold separately at $330. Isn't the 585 the better cam? Why wouldn't they put the better cam with the new upgrade SE 117CI kit? Is the 295 actually better for the larger motor? Am I missing something here, or is this just one more HD design to force you to spend several more H-D's (Hundred Dollars).
stillsoldier4christ is offline
post #2 of 10 (permalink) Old 09-10-2016, 09:37 AM
Smarty's Avatar
Neither, put the S&S 585 in it and you will be a very happy camper!
2016 RGS Black Quartz
Smarty is offline
post #3 of 10 (permalink) Old 09-10-2016, 09:47 AM
FDR's RGC's Avatar
TW 777 would be my choice. Any cam is better than HD
FDR's RGC is offline
post #4 of 10 (permalink) Old 09-14-2016, 06:21 AM
Wood 9B, with a proper set of heads.
It'll "hit" off the bottom, and rip it all the way to the end.
Scott
sloride likes this.
Hillsidecycle.com is offline
post #5 of 10 (permalink) Old 09-14-2016, 07:45 AM
SteadyEddie's Avatar
TW 999..........590 - You'll thank me later - I have them on my 117 Kit and have ZERO complaints
SteadyEddie is offline
post #6 of 10 (permalink) Old 09-17-2016, 10:59 AM
Dragon Dude's Avatar
I have purchased the Rockouts, S&S standard lifters and all the gaskets i will need to do a cam upgrade. It is a very hard decision on which cam to use. I am looking at the Andrew 57h cam, Andrew 48h, and the S&S 551. Right now my bike is stock with just the baffles removed w/stock air cleaner. I am thinking of using the S&S adjustable push rods instead of the stock ones if it is a must. I will eventually buy a TTS tuner, pipes, and a better air cleaner. Not wanting a race bike but wanting more power on the low to mid range area. OK, here it comes, is there a better cam than i have listed that you can recommend that's better for low torque performance without head work? I am just gathering all the parts i will need so when i get started i will have everything right there to finish up. I know this is like the which oil is better subject but i am stumped on which cam to invest in. Thanks.
Dragon Dude is offline
post #7 of 10 (permalink) Old 09-17-2016, 12:17 PM
09 YELLOWBIRD's Avatar
I passed on the SE259 cams and stock lifters in the 117" kit.
Aftermarket for both, I drank the Koo-Aid and went GMR 577 & GMR Lifters.
Happy, happy, happy for now. Come this winter, sending Heads down south
and getting hopefully my final dyno tune!
YB
sloride likes this.
2009 SCREAMIN' EAGLE CVO ROAD GLIDE FLTRSE3 117" PRO RACE
(1 OF ONLY 369 U.S.) "LAST YEAR OF THE HAND BUILT"
09 YELLOWBIRD is offline
post #8 of 10 (permalink) Old 09-17-2016, 01:01 PM
Smarty's Avatar
I would seriously look at the S&S 585 for your build. Also, the new zippers 587 I think for 110's might be a good option. We put it in a CVO SG stock 110 and it made 104 hp and 118 tq. Really nice curves and came on at about 2700 rpm at 100tq. If doing heads, I would go with the 585 in a heartbeat.
Smarty is offline
post #9 of 10 (permalink) Old 09-17-2016, 04:52 PM
pipe3214's Avatar
Like you I was almost all stock had pro pipe and air intake went with a set a Kuryakyn TC24D and was super impressed. Dealer that installed them was so impressed with the Dyno #'s he now uses them in most of his builds.
pipe3214 is offline
post #10 of 10 (permalink) Old 09-19-2016, 08:54 AM
+1. For a bolt in, ecellent results.
rg113 is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
Gear Drive Cams??? sportyguy69 Engine Related 17 11-16-2010 04:46 PM
551 vs 585 cams watty Engine Related 4 11-16-2010 03:29 PM
Woods TW6H CAMS OR SE251 IN 95CI tr17047 Engine Related 2 06-23-2010 12:02 PM
