120r v r and r 117? - Road Glide Forums
post #1 of 11 (permalink) Old 02-02-2013, 11:42 AM Thread Starter
captten's Avatar
120r v r and r 117?
I have an 09 RG with an R and R 103. badass and x country twice with zero problems. blows my friends 2010 SG SE away. he hates me. As you know the MOCO cranks are not true and I had to have the lower end done to swap to gear driven cams, which are Andrews 615. to much stuff on the complete bike to list
My question is this. I'm looking into getting another bike to rip around the local mountains in northern New England. I was thinking aboiut throiwing the 120r in but hear there are warranty issues with Jims, chain driven cams. Which leads me to think that the cranks are not trued and balanced. $1700 to have that repaired.
What do you guys think? Pros and Cons of the Jims 120r v an R and R 117?
captten is offline
post #2 of 11 (permalink) Old 02-02-2013, 12:07 PM
Personally, I'd do the R&R 117...simply because the crank will be balanced and welded with the Timken bearing set-up.
I'm running a "mild" 117 in an 05 softail...the thing runs like a raped-ape, nice and cool, and I have "piece of mind" that the crank will last for a very long time.
I'm sure you'll get lots of opinions, but if it were me...I'd go the 117 "if" it's easier on the pocket-book than the 120-R after you pull it apart to get the crank-thing all dialed in.
So there....go ahead an rip me to shreds....JMHO.
DaFrankster is offline
post #3 of 11 (permalink) Old 02-02-2013, 12:21 PM
Torquey's Avatar
R & R Makes a 155 cubic inch chromed billet engine???
...palms getting sweaty now...
Torquey is offline
post #4 of 11 (permalink) Old 02-02-2013, 01:15 PM
FLTR2008Trike's Avatar
If your willing to spend the money for a 120r I would suggest looking at the S&S 124" engine for 2007 and newer touring bikes. The crank is not a issue with them.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #5 of 11 (permalink) Old 02-02-2013, 01:53 PM Thread Starter
captten's Avatar
so far I'm reading what I thought. my current 103 was done twice. 1st time by my HD dealer then I got my learn on and had R and R do it from scratch. Twice the loot but the end result was worth it. Money is always a concern which is why I'm gunna buy this one used. Mark at R and R is working on a quote for an 88 to a 117 and I shoulod have that on Monday. Ive no doubts about them but was curious about the 120 and when asking around I started asking around, talk about the lower end on the 120 started coming up. NFG.
captten is offline
post #6 of 11 (permalink) Old 02-02-2013, 02:41 PM
11FLTRX103's Avatar
Re: 120r v r and r 117?
Hell might as well throw in the 140cui ultima black gem if you wanna go big or go home
11FLTRX103 is offline
post #7 of 11 (permalink) Old 02-02-2013, 03:11 PM Thread Starter
captten's Avatar
so far i'm reading what i thought. My current 103 was done twice. 1st time by my hd dealer then i got my learn on and had r and r do it from scratch. Twice the loot but the end result was worth it. Money is always a concern which is why i'm gunna buy this one used. Mark at r and r is working on a quote for an 88 to a 117 and i shoulod have that on monday. Ive no doubts about them but was curious about the 120 and when asking around i started asking around, talk about the lower end on the 120 started coming up. Nfg.
it's not yours, til you void the warranty
captten is offline
post #8 of 11 (permalink) Old 02-02-2013, 03:14 PM Thread Starter
captten's Avatar
Grey Beard, Be nice to keep the price under 20 G's. This bike will b local while the other one is for messing with the guys I work with. They all have touring bikes but dont like leaving their home turf, without a trailer
captten is offline
post #9 of 11 (permalink) Old 02-02-2013, 03:22 PM
digga25's Avatar
Capt,Mark and Reggie did my 117,from a 110 platform and I am very happy with the results.Plan on getting a new clutch though because the stocker wont hold.Had to replace mine with a Rivera Primo lockup.
digga25 is offline
post #10 of 11 (permalink) Old 02-02-2013, 09:13 PM Thread Starter
captten's Avatar
digga. i have to get the same clutch for my 103. SE spring cant keep up with the demand. what were your dyno digits? I'm guessing you had to have your crank trued. How big did you go on your cams? I gotta plan my build a little better this time. Broke the 103 in, in Feb. Hats off to my Carthart one piece, saved my dumbass.
captten is offline
120R and 660SMs JRB_RME5 Engine Related 8 08-22-2014 12:19 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 10:31 AM
Clutch for 120R bigtwin Engine Related 3 02-15-2011 08:52 AM
Pcv map for 120R bigtwin ECM/Fuel Management systems 0 11-12-2010 11:49 PM
SE 120r NakedSnowman Engine Related 22 10-13-2010 01:43 PM
