Which Head? - Road Glide Forums
post #1 of 13 (permalink) Old 02-03-2013, 08:33 PM Thread Starter
jack6hd's Avatar
Which Head?
Will a ported OEM head perform the same as a ported SE head? Both with the same size valves.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #2 of 13 (permalink) Old 02-03-2013, 08:43 PM
spokanebagfan's Avatar
Depends a lot variables. The ported set may be better as it may flow a lot better. I have heard a set of the se heads still need all of work.
spokanebagfan is offline
post #3 of 13 (permalink) Old 02-03-2013, 08:47 PM
Would probably be best to contact the head porter you plan to use, and ask them what they prefer for a donor head. While you're at it, describe your riding style, and power expectations, and have them choose the cam as well.
Jeff
akjeff is offline
post #4 of 13 (permalink) Old 02-04-2013, 07:03 AM
The re-worked head will out-flow, not only peak numbers, but all the way thru as well.
Scott
Hillsidecycle.com is offline
post #5 of 13 (permalink) Old 02-04-2013, 08:10 AM
OldNerdGuy's Avatar
Jeff
I have not had the head ported (yet!), but this is exactly how I had my Cam chosen. I did not pick it, Bob Woods picked it after hearing about my riding style. They indie guy who bored out my engine also picked the pistons. Nothing fancy, flat top cast pistons. Said I did not need anything more expensive.
Oh, and in case anybody is wondering (you know who you are), I did not port the heads because I used up the budget boring it out to a 103, cams and lifters. I got what I wanted, for now.
Gotta question for those who know more than I do about this. I have heard that if you port your heads, they will run a bit cooler. Is this true, and if so, can someone explain this? I was thinking of (as I heard it called) a Street Port. I have stock '09 96 heads.
OldNerdGuy is offline
post #6 of 13 (permalink) Old 02-04-2013, 08:22 AM
prodrag1320
Guest
Posts: n/a
our street port heads will flow about the same as SE heads,our stage II & III easily out flow SE`s
post #7 of 13 (permalink) Old 02-04-2013, 08:25 AM
riptilyaflip's Avatar
Scott
I understood the question to be; which core would perform better, given the same valve and porting job.
riptilyaflip is offline
post #8 of 13 (permalink) Old 02-04-2013, 09:59 AM
faststan's Avatar
That was my understanding, also. I think the question related to capability of each casting.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #9 of 13 (permalink) Old 02-04-2013, 02:11 PM
prodrag1320
Guest
Posts: n/a
dont think thats what he`s asking,i think he`s asking if a ported stock casting will flow as much as a "out of the box" SE head,maybe the OP can chime in
post #10 of 13 (permalink) Old 02-04-2013, 03:39 PM
faststan's Avatar
I believe he is comparing an apple with another apple. OEM casting and SE casting.
faststan is offline
*Which Pistons?? Which Tuner??* HELP! Iron1 Engine Related 2 02-08-2017 08:15 PM
Which head gaskets in 92500005 iv kit Sloverado Engine Related 1 02-17-2015 04:51 PM
which head unit should I get? smhusker Audio 7 05-10-2014 08:02 AM
Which Head Pipe is Best All Around Choice Bud Intake and Exhaust 37 03-13-2011 05:06 PM
