How Important is This??...... - Road Glide Forums
post #1 of 21 (permalink) Old 02-04-2013, 11:01 AM Thread Starter
Found out a couple weeks back that the "run-out" on the crank is .004 out. So the question becomes should I send out the crank and have it "trued"? I would like to do an up-grade kit from this company, http://www.head-quarters.com/html/tc113_kits.html at some point. I've already installed the "HV" camplate and oil pump from Feuling and it's nice. But the crank is only .004 out, so how important is it really.......
Nevadasun
post #2 of 21 (permalink) Old 02-04-2013, 11:27 AM
mocotom's Avatar
I don't like anything over .003, others will have their own opinion. What year is your bike and how many miles?
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #3 of 21 (permalink) Old 02-04-2013, 12:18 PM Thread Starter
2010 and going on 32k
post #4 of 21 (permalink) Old 02-04-2013, 01:05 PM
StephenRG's Avatar
I'd go with anything Doug, Duke, or Boz (HQ guys) recommend. I've gotten excellent advice and perfomance from them. I'm on my third HQ motor and strongly recommend them to anyone that will listen.
I trust them enough that I drove (bike in the back of the truck ) 1,400 miles (one way) to have Duke break in and tune my bike. Ended up redoing everything a local independent did, but that's a whole other story.
Check out the Yahoo group they have. There is a lot of great information there and they answer any questions you might have.
In my opinion you've made an excellent choice. They have a proven 'formula' that works when followed. I sacrificed a bit of performance by not following some of the recommendations but for me it was a 'looks' thing (dual exhaust and intake).
Stephen
'10 RG "Black Betty"
HQ 103"
HQ 575 cam
SEPRT
16" TRSSC Cee Bailey Windshield
Sancho's Wings
Mustang Seat
J & M Speakers
Drago's True Duals
Apparently not as black as I thought...
StephenRG is offline
post #5 of 21 (permalink) Old 02-04-2013, 01:20 PM
tdkkart's Avatar
If you're going the 113" route using Doug's kit you'll need to bore the cases for the cylinders to fit. The cases have to come out and be split anyway, perfect time to get the crank true'd and welded. I wouldn't pull the crank JUST for .004", but if it's coming out anyway there's no excuse not to.
tdkkart is offline
post #6 of 21 (permalink) Old 02-04-2013, 01:33 PM Thread Starter
Stephen, thanks for input, really. ......maybe I'll give them a call today. Thanks again.
post #7 of 21 (permalink) Old 02-04-2013, 02:17 PM
StephenRG's Avatar
They're pretty hard to get in touch with over the phone and try to discourage it. Try the Yahoo forum they have in the Customer help section of the web site or the tech email address they offer.
I've always had good response with the forum.
Good luck and enjoy!
Stephen
HQ 103"
HQ 575 cam
SEPRT
Sancho's Wings
Mustang Seat
J & M Speakers
Drago's True Duals
post #8 of 21 (permalink) Old 02-04-2013, 02:22 PM
At .004 your crank is probably better than half the 07 and up engines out there. Unless you plan to use gear drive cams or go bigger on your engine, I wouldn't even worry. If you do upgrade that's the time to weld and true the crank.
post #9 of 21 (permalink) Old 02-04-2013, 03:41 PM
prodrag1320
Guest
Posts: n/a
if your doing a hi-po build (witch i guess you are or you wouldnt be looking @ HQ stuff),have the crank trued,pinned & welded
post #10 of 21 (permalink) Old 02-04-2013, 04:17 PM
PFWiz's Avatar
I asked the same question last fall.
My Indy said anything under .006" was fine.
I also asked Frank Drago, he said anything up to .0065" was acceptable.
I take just about anything Frank says about Harley performance as gospel and my Indy agreeing with him can't be a bad thing!
PFWiz is offline
IMPORTANT Safety Recall - 2009-2012 4getNo1 Safety Area 22 06-27-2012 12:03 PM
Important - gypsy tour hotel reservations - important HUTMO ARCHIVES-SWII LeClaire, IA 0 06-18-2012 12:36 PM
Important Reminder Uncle Fuzzy *General Road Glide Discussions/Pictures 19 02-12-2012 12:33 PM
Important Lesson Peewee *General Road Glide Discussions/Pictures 4 10-09-2010 05:52 AM
How important is ABS(to you) Rooster *General Road Glide Discussions/Pictures 26 08-04-2010 09:52 AM
