High compression pistons - Road Glide Forums
post #1 of 19 (permalink) Old 02-08-2013, 09:23 PM Thread Starter
chefskeeter's Avatar
Has anyone put in high compression pistons? and if so what was the result? please let me know
[FONT="Comic Sans MS"]2017 Road Glide Special 114,SE Hi flow intake, D&D M8 BILLET CAT 2:1, SE447 cam, TTS master tune
chefskeeter is offline
post #2 of 19 (permalink) Old 02-08-2013, 11:31 PM
I put in the 10.5:1 H-D pistons, along with other motor work. Very strong and definitely has more exhaust pressure. Definitely worth it!
BW TC-44 cams; Fueling race lifters; SE Pro Tuner, ported/polished heads, 10.5 pistons, HV oil pump/camplate; RSD AC; Fullsac/Rinehart 4"
MadCVORG is offline
post #3 of 19 (permalink) Old 02-09-2013, 02:48 AM
mitchdm's Avatar
10 1/2 to One on the CVO - HD also ~ This was the dealers demo and he stage III'd ~ there are some other tricks to bumpin compression up ~ Head Gasket for starters. I can only tell you that I am at 104/109tq ~ not sure of the stock cvo configuration....
mitchdm is offline
post #4 of 19 (permalink) Old 02-09-2013, 08:01 AM
prodrag1320
Guest
Posts: n/a
if you put in high compression pistons,the result will be higher compression.this will result in more HP/TQ,this can also result in alot of problems if compression isnt matched to a set of cams.best to have a good build worked up by a good builder.we can put together a couple proven builds together if you want
post #5 of 19 (permalink) Old 02-10-2013, 07:33 AM
The intake closing number of your cam(s) will dictate the compression needs for the cam to be the most effective, in any given engine combination.
Feel free to give us a call, and we are happy to discuss this with you.
Scott
Hillsidecycle.com is offline
post #6 of 19 (permalink) Old 02-13-2013, 11:28 AM
unbalanced's Avatar
Mitchdm,
Typically the stock 110 makes 80-90 hp stock, and 90-100 torque. I would have expected a tiny bit more torque from your build though roughly looking at 115, but might just be a stingy dyno.
2-1-2 exhaust with catalytic converter on the touring
Open air breather
255 cams
-Unbalanced
He who laughs last thinks slowest.
unbalanced is offline
post #7 of 19 (permalink) Old 02-14-2013, 06:20 AM
A Wood 777 set at 10.4-5, will blow off 115/125 in a 110", as Lone Wolf Perf,tned one with a set of our Stage II CVO Heads/777/Fulsac exhaust combo.
Doc just tuned STGHost's 107"er to just a tick less.
We stay away from the WILD compression, as gas is not getting any better.
Scott
post #8 of 19 (permalink) Old 02-14-2013, 08:07 AM
mitchdm's Avatar
The stage III was done by the dealer before I purchased the Skunk ~ Current Output is 104/109tq. Specs are in my signature. Bike is strong but I'm going to change cams to 777's and having a set of 110 heads reworked for better results.
mitchdm is offline
post #9 of 19 (permalink) Old 02-14-2013, 08:55 AM
Durwood's Avatar
Mitch are you running the 255 cams? That thing ought to be close to 120 tq,I suggest getting a good tune..JMO
Don't forget the tune.
Durwood is offline
post #10 of 19 (permalink) Old 02-16-2013, 10:28 AM Thread Starter
Thanks Scott for your time on the phone big help.
High compression 103 13glidespoked Engine Related 18 09-22-2018 07:44 PM
11.25 pistons added whatís the compression? freedom1974 Engine Related 57 01-31-2018 12:04 AM
High Compression Pistons for the HD 110 Upgrade kit - input oc357 Engine Related 2 06-17-2016 07:05 AM
95'' heads high compression pistons and cams OuchMMC Dyno Results 18 04-04-2012 12:14 AM
