I have No Idea!!!! - Road Glide Forums
post #1 of 15 (permalink) Old 02-10-2013, 08:58 PM Thread Starter
I have No Idea!!!!
I have a 2009 road glide cvo screamin eagle 110 with a stage one air cleaner, Vance and Hines X Pipe and CFR exhaust the bike also has a tune with Harleys race tuner, now I apolojize if I sound stupid about some of this but I am a novice when it comes to engines and the Harley dealer just wants to sell me a 120R and that isnt what I am looking for. From the homework I have done I have found out from Doc that the bike has 255 cams and they dont work well with CFR exhaust, I want more performance but nothing crazy or too expensive so I was just thinking to change the cams? any idea's? recently I rode with a couple of guys that had 09 road glides with 107's and they just left me behind, they said they were shifting at around 4k RPM or even higher and there bikes screamed, they were running d&d fatcats and with the cams it sounded unreal. Thank you for any help you can give.
METIME is offline
post #2 of 15 (permalink) Old 02-10-2013, 09:07 PM
RoadGlideGary's Avatar
Cams, big bore, or?
Sounds like you have a 96? Start with cams that you can build from for a big bore in the future. Bike maybe running lean too even though you have a tuner. Give Jamie at FM a call for advice you can trust.
Post edit: Okay after reading posts subsequent to mine I realized I have no idea how I missed the stated! My bad. I blame winter and no fresh air resultant from riding!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 15 (permalink) Old 02-10-2013, 10:11 PM
pacfan1967's Avatar
The 09 CVO was only offered with the 110 and 255 cams from the factory. Unless I've missed something..........
Asking cam questions will get you a million answers and questions back. I'm no expert so I won't offer advice. Curious, Do you know if your cats are still in the head pipes?
Ride safe, Gary
pacfan1967 is offline
post #4 of 15 (permalink) Old 02-10-2013, 10:15 PM Thread Starter
Yes its a screamin eagle 110, the stock head pipe was replaced with the vance and hines x pipe.
METIME is offline
post #5 of 15 (permalink) Old 02-10-2013, 10:47 PM
pacfan1967's Avatar
Duh!!! You said that up there and I missed it!
Check out the dyno run results at Wood performance. Will give you some ideas of the various cam choices.
http://www.woodcarbs.com/dynoruns.htm
Ride safe, Gary
post #6 of 15 (permalink) Old 02-11-2013, 12:06 AM
The stock 110s are slow, from what I am able to gather, a cam change really perks them up.
I have a V&H x pipe and like it, the tuners that I have spoke with, say the x pipe is good to go with certain mufflers.
Personally, I am pretty much set on the SE stage III kit w/259e cams and the 10.5-1 pistons, and either PowerVision or TTS
HeatWave is offline
post #7 of 15 (permalink) Old 02-11-2013, 08:51 AM
pacfan1967's Avatar
A couple more things to consider -
You might get more out of the bike with head work as compared to swapping cams. Head work will help everything flow better and a lot of guys, that ride the CVOs, will tell you that is a must. The SE255 cam pulls hard in the low end to mid range. So depending on your riding style/needs it might be fine. I've never heard that they don't work well with the CFRs.
Also, you might simply have a bad tune.
Again, just my two cents and I'm definitely no mechanic.
Ride safe, Gary
post #8 of 15 (permalink) Old 02-13-2013, 08:49 AM
MyGlide's Avatar
Those V&H x-pipes are good performing pipes. Your cfr's are killing your low end and the 255's are low end cams that fall off early, so you're losing on both ends. If you were to get some different mufflers and cams like the Andrews 57 or the new Kuryakyn tc24d(should be available within a few weeks) with a good tune you would have a very strong running 110. Ask any tuner for their recommendations for good performing mufflers, you probably won't get any to suggest the cfr's. I understand they sound great, but if you really want to realize the most performance for the least money you will probably have to chose something different.
2018 KTM Super Duke R
MyGlide is offline
post #9 of 15 (permalink) Old 02-13-2013, 11:14 AM
unbalanced's Avatar
What MyGlide has stated is correct, the CFR's are open so no low end back pressure to be found. You might look at the crusher mellows for mufflers and the 24d cam as a good starting point. From there compression / larger throttlebody, headwork.
Another decent combination is the Andrews 54, .030 headgasket, some headwork bring compression to 10 to 1, spin drop the heads to help the squish since your pistons are most likely in the hole or below cylinder deck height. exhaust recommendations remain the same or look into a good 2 -1 pipe which will only help further.
-Unbalanced
He who laughs last thinks slowest.
unbalanced is online now
post #10 of 15 (permalink) Old 02-19-2013, 06:17 AM
There IS NOT, a cam out there, in the 10.0 cr range, that will stand toe to toe, with an S&S .570.
That, combined with head work will bring that engine to life.
Big, broad, cool running, power.
Scott
Hillsidecycle.com is offline
I have an idea......now what? cloud General Off-Topic Discussions 9 06-05-2014 05:41 PM
Newby with no idea ozymax Audio 21 10-12-2013 07:18 PM
Florida boy had no idea FloridaFLTRU Road Trip Discussions/Stories/Pictures 4 05-26-2013 09:16 AM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
i have a idea about windshields cestaro Windshields 5 07-22-2011 10:00 AM
