Good read about cams - Road Glide Forums
post #1 of 8 (permalink) Old 02-16-2013, 10:46 PM Thread Starter
jim_b's Avatar
Found this online. Probably more info than I will ever need on cams.
http://www.harley-riders-guide.com/h...dson-cams.html
Thought I'd share.
2010 FLTRX Vivid Black With Supertrapp Fatshotz, V & H Dresser Duals, PCV, Big Sucker, SE 255 Cams, 12" Wild 1 Outlawz, MadStad 16", HogTunes Amp/5x7 Fairing Speakers, Mustang Wide Tripper W/Pillion, List Goes On And On
jim_b is offline
post #2 of 8 (permalink) Old 02-16-2013, 10:56 PM
598Malibu's Avatar
Thanks ill be checking that out.
2012 Big Blue Pearl FLTRU
72 Chevelle with Procharged 598
598Malibu is offline
post #3 of 8 (permalink) Old 02-16-2013, 11:01 PM
06SuperG's Avatar
Thanks, good read.
06SuperG is offline
post #4 of 8 (permalink) Old 02-17-2013, 12:15 AM
Mostly factual
No mention of Valve to Valve clearance which is important with high TDC lifts on overlap when both valves are open.
I don't agree with the data presented about exhaust flow ratios but that is just my opinion VS his and our respective experience.
Deweys is offline
post #5 of 8 (permalink) Old 02-17-2013, 08:28 AM
prodrag1320
Guest
Posts: n/a
good info for the average guy to help in cam choices,ive read it before,not sure where it was reprinted from (HD high performance tuning manual by william denish,i think) maybe not so many guys will call us wanting to put
.625`s in the 88"ers after reading it!!
post #6 of 8 (permalink) Old 02-18-2013, 10:59 PM
Shark of the Month August 13
SIC_26's Avatar
Cams are around the corner for me, so I'm marking this for later reading
SIC_26 is offline
post #7 of 8 (permalink) Old 02-18-2013, 11:19 PM
CHAINSAW's Avatar
Good read, and its not some company trying to push their cams on you. Just good solid info.
Such is the rule of honor.
CHAINSAW is offline
post #8 of 8 (permalink) Old 02-19-2013, 07:29 AM
prodrag1320
Guest
Posts: n/a
i agree 100%,be very carefull choosing a cam from what some might say,if it sounds to good to be true,it probley is.we use cams from just about every manufacture out there for different builds,
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
I've read and read and still confused. Advice needed. miztrz99 Audio 10 05-02-2013 05:13 PM
Good Read About Amps! Donk Audio 0 03-20-2011 07:52 PM
Good read pisssed ECM/Fuel Management systems 0 12-07-2010 11:34 PM
Really good read jbrushoe Engine Related 4 11-06-2010 09:17 PM
