Is there still a cam tensioner issue - Road Glide Forums
post #1 of 25 (permalink) Old 02-25-2013, 09:46 AM Thread Starter
mr_reality's Avatar
Is there still a cam tensioner issue on the newer bikes? Since the change to the hydraulic tensioners what is the life expectancy? Sorry if this has been asked and answered.
2013 Road Glide Custom "Jezebel"
2009 KLR 650
mr_reality is offline
post #2 of 25 (permalink) Old 02-25-2013, 09:54 AM
I read in a thread its around 50 K But other said they had more miles with no problem.
post #3 of 25 (permalink) Old 02-25-2013, 10:02 AM
The ones that I see with the most wear are the ones that have alot of crank run out, say .005 to .0075. The other thing I see with OEM parts is the cam plate gets cracks in them, and again I think this is also caused by to much run out.
chuck the wrench is offline
post #4 of 25 (permalink) Old 02-25-2013, 10:03 AM
Not exactly sure of life expectancy, some people report going 70k on the new hydraulic tensioners. The inner tensioner usually wears a little faster. In the pic below these tensioners have right at 30k on them. As you can see, very little wear. This may not exactly answer your question but, it may give you some idea of what to expect.
Nevadasun
Ps. the runout on my crank is .004
post #5 of 25 (permalink) Old 02-25-2013, 10:04 AM
93-331-29psi's Avatar
I've read the same as well, but figure that anytime that side of the engine gets opened up I'll replace them. Cams for me next winter so they'll be replaced.
93-331-29psi is offline
post #6 of 25 (permalink) Old 02-25-2013, 10:10 AM
glideriderdave's Avatar
Just had replace my main drive gear bearing due to a tensioner that kept the primary chain too tight on a 2010 RGC at 29,000 miles. Compensator was knocking on startup so replaced it with a Screamin Eagle compensator, Baker adjustable tensioner along with bearing. Bad design in my opinion on the tensioner, but that's the MOCO for you.
glideriderdave is offline
post #7 of 25 (permalink) Old 02-25-2013, 10:11 AM
I replaced mine, simply because I was in there. At nearly 25k miles, they basically just had shiny spots worn on them, that could barely be detected with a fingernail. My pinion run out was .003".
Jeff
akjeff is offline
post #8 of 25 (permalink) Old 02-25-2013, 10:43 AM
Has anybody consider going to gears and end the worries? The thread I read actually said they will fail do to pressure problems rather than wear limits.
Like I said this is only something I read and have not experienced it or heard from anybody I know.
post #9 of 25 (permalink) Old 02-25-2013, 10:48 AM
Redfish-Joe's Avatar
I put a set of cams in a 08 Street Glide with 51 k on the clock. The inner had no wear and the outer had minimal. Barely enough to feel with a fingernail.
sputnik likes this.
Redfish-Joe is offline
post #10 of 25 (permalink) Old 02-25-2013, 11:21 AM
mocotom's Avatar
Never heard of this and have not found any problems related to pressure, but it may be a possibility if oil pressure was excessive. Gears are a great way to go if the crank run out will allow, but far too often it won't.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Cam suggestions for 2000 also cam chain tensioner upgrade dirtracer27x Engine Related 22 04-09-2014 08:47 AM
TC88 Cam/Cam tensioner advice zglide2003 Engine Related 2 08-31-2012 12:01 PM
Hydraulic chain cam tensioner kit ohd24 Engine Related 7 06-30-2012 08:24 AM
Anyone beat,1999 twin cam 90000 miles still got original cam tensioners Bigtrev8xl *General Road Glide Discussions/Pictures 11 04-22-2012 01:29 AM
Cam chain tensioner question SKULLZ *General Road Glide Discussions/Pictures 5 05-14-2011 03:29 PM
