Flow Numbers!! - Road Glide Forums
post #1 of 10 (permalink) Old 02-27-2013, 02:38 PM Thread Starter
BlackDangerous's Avatar
Flow Numbers!!
I am inching closer to having my Glide put back together for the upcoming riding season. I am almost there, have pretty much the single biggest part of the project near complete, the head work. I have the flow data for them and thought that I would share the information with all of you. There are two charts, Before the head work and after the head work was done. Enjoy!
BlackDangerous is offline
post #2 of 10 (permalink) Old 02-27-2013, 02:42 PM Thread Starter
I forgot to note that the spring pressures used are notated at the bottom left of the Ported Chart.
post #3 of 10 (permalink) Old 02-28-2013, 06:41 AM
Why do they flow in reverse, out past .450" lift?
Scott
Hillsidecycle.com is offline
post #4 of 10 (permalink) Old 02-28-2013, 08:07 AM
prodrag1320
Guest
Posts: n/a
im wondering too,wierd way of charting,or are the heads just petering out above .450??
post #5 of 10 (permalink) Old 02-28-2013, 06:47 PM
Choke and/or turbulence. Sometimes an easy fix sometimes scrap.
Deweys is offline
post #6 of 10 (permalink) Old 03-01-2013, 10:16 AM Thread Starter
Your reputation proceeds you. If you could, please explain further as to why you think this scrap possibly???
post #7 of 10 (permalink) Old 03-01-2013, 01:24 PM
prodrag1320
Guest
Posts: n/a
heads that the flow drops off at .450 lift wont work that good at all.what he`s saying is,sometimes more work can be done & more air flow can be had,other times,the heads FUBAR`ed.decent heads will have the CFM climb atleast to .600".heads that stop flowing @ .450" will make for a very flat,soft build
post #8 of 10 (permalink) Old 03-01-2013, 05:47 PM
What prodrag said sums it up perfectly.
Too much or not enough material removed and or in the wrong spots. Too little is easy to fix. Dewey Jelen (my predecessor) used to turn down the $299 Street Port heads done by others for rework. I will take them all day long. They don't do much to them. The polish doesn't hurt (doesn't help either)
There are about a half dozen things common that can cause what we see and many other not so common ones. Measuring and testing would tell the story plus just a look by an experienced eye. If the person that worked the heads put an oversized valve on the stock seat it would do that. IME one that runs out the back door a little (still increasing flow) at .6 and .7 will work better even if the cam is .5 lift assuming the low lifts weren't murdered to get the top lift numbers and the port is quiet (not turbulent).
YMMV and..
They may be OK
We don't have a clue what was used for test fixtures or other factors that can skew the numbers.
Deweys is offline
post #9 of 10 (permalink) Old 03-01-2013, 06:26 PM
mocotom's Avatar
If material has been removed from the wrong areas of the intake and-or exhaust track, you can cause a turbulence that will stall the air flow causing no gains beyond a given lift. Depending on what has been done to the head, it's hard if not impossible to correct the mistake. It may be more cost effective to start over with other heads. A good head porter will be able to make that call.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #10 of 10 (permalink) Old 03-02-2013, 06:38 AM
As Don said, port turbulence, or the fact that they are restricted, will cause that.
You can actually hear that noise, when working with a head that has been "ported", prior to resurecting it.
We've able on many occasions to "pull a rabbit out of our hat" when re-working, others, port work.
Scott
Exhaust flow. Rkfltrx Intake and Exhaust 4 06-01-2012 04:54 PM
Oil Flow path 1st Sgt *General Road Glide Discussions/Pictures 2 12-13-2011 02:08 AM
Anyone using a S&S high flow air cleaner Hawkeyestoob Road Glide Specific Discussions 9 08-13-2011 10:07 AM
Under fairing flow diverters Pixman Aftermarket Accessories 1 08-28-2010 10:08 AM
MO FLOW Air cleaner hdtwincam *General Road Glide Discussions/Pictures 1 05-21-2010 09:41 AM
