whos running gates polychain with 30t - Road Glide Forums
post #1 of 15 (permalink) Old 02-27-2013, 05:08 PM Thread Starter
i am about to install the 30t pulley. i was wondering whos running the gates polychain 139? ive read about the swing arm mod whch isnt to bad of a job.im just not sure what route to go? i read about alot of belts breaking! just not much on the polychain. so im curious to see if anyone has broke the poychain or even a stock belt with the swing arm mod?
jsdmax is offline
post #2 of 15 (permalink) Old 02-27-2013, 07:29 PM
torqu's Avatar
You state that alot of belts brake?? I'm not sure what problems some are having. My last Fltr I would go through 2-3 rear tires a year doing massive burnouts. 33k never had an issue with the belt or the pulley, but I never had the dealer touch the bike either. Those years the belts were wider, not sure if that makes a difference. Harley used to sell a reinforced belt for the sidecar bike, that some guys would swear by. Good luck on your search
torqu is offline
post #3 of 15 (permalink) Old 02-27-2013, 08:54 PM
hilltoptim's Avatar
Talking 136" Polychain
I changed to a 30 tooth trike pulley from stock 32 last Sept. I've put @ 6000k
Miles on the bike since. No problems. I don't do hole shots or burn outs. I enjoy my bike and don't mind working on it , but I don' need to create extra work.
hilltoptim is offline
post #4 of 15 (permalink) Old 02-28-2013, 10:43 AM
sonic_cruzer's Avatar
Went to the 30t pulley and installed a Gates Polychain 136 last Oct. Also installed a SE Compensator & Primo Rivera Pro Clutch (w/variable pressure plate). Haven't put many miles on it since but I do like the improvment. Now to install a new TW-222 cams, lifters & adj pushrods. I probably will think I bought a new bike this summer.
2008 Vivid Black RG, CB TRSSC, Ohlins #2~#2B on Rear, -1" Progressive Monotubes in forks, RP EMS Tuner, TW-222 cams, Kromewerks Sweeper +2 bars, Rivera Pro VP Clutch, SuperTrapp 2:1 Exhaust, SE Compensator, Medallion Gauges, UltraCool, all lighting is LED including Daymakers.
sonic_cruzer is offline
post #5 of 15 (permalink) Old 02-28-2013, 11:06 AM
glide69's Avatar
the OEM belts are pretty tough my TURBO V-ROD had the same width belt as the glide has and pushing 160 hp at the 260 rear tire used to rip whole shots all the time 30 feet long 2 gears and had over 50k on the original belt so they hold up!! I personaly would go with the belt.
2018 FLTRXS Wicked Red
glide69 is offline
post #6 of 15 (permalink) Old 12-19-2014, 01:53 AM
Easyryder01's Avatar
What's the point to a 30T ? I thought going up in teeth would allow tranny to lower rpm's ?
2017 RGS Velocity Red
Easyryder01 is offline
post #7 of 15 (permalink) Old 12-19-2014, 02:24 AM
tmd
Going down in teeth lowers the overall final drive ratio giving better acceleration. On the flip side you run higher rpms across the board.
tmd is offline
post #8 of 15 (permalink) Old 12-19-2014, 08:38 AM
Approx how much higher would the rpms be?
rlaf75 is online now
post #9 of 15 (permalink) Old 12-19-2014, 10:56 AM
chromedome's Avatar
I would guess about 6.2% higher. That's based on comments earlier in the thread that the stock belt is 32 tooth and the replacement would be 30 tooth.
that's a difference of roughly 6.2%. translate that to a normal running rpm of 2500 would now be 2655 rpm.....
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #10 of 15 (permalink) Old 12-19-2014, 11:19 AM
twistr's Avatar
I will be going to a 30t over the winter break (no snow yet in my part of the sticks) so still riding. Once the real bad weather hits onto the lift she goes.
the site below will give you the info your looking for...be sure to enter your rear tire size too...change the front or rear gear and it will show you rpm's / speed in every gear...plus other info: Cool tool to have, enjoy it:
http://www.gearingcommander.com/
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
31 tooth pulley and polychain belt GroundPounder Parts for Sale 5 11-28-2014 01:40 PM
30T trans pulley for 120R '13 FLTRX - belt teeth? JRB_RME5 Engine Related 12 09-28-2014 08:54 PM
Bill Gates is stealing our Name! OldNerdGuy ARCHIVES-SWIV NH & ME 3 04-29-2014 02:53 PM
Changing to a 30T transmission sprocket RoadGlide0611 Do-IT-Yourself 4 11-07-2012 08:14 PM
whos selling a 14" windvest? I need it ! mea4dxl Windshields 8 04-10-2011 12:59 PM
