Need help- clutch hub nut - Road Glide Forums
post #1 of 6 (permalink) Old 03-05-2013, 05:08 PM Thread Starter
called my local parts guy. They dont make a clutch hub locking plate for anything later than 06 ? need something to lock up the hub from spinning. searched around and im finding guys saying apply brake, rope, clothes?, make a tool welding disc and steel together. There has to be a better way?? Does anyone know of a company who makes the locking tool for new HD clutch? I tried jims already, no go
THEMASTERDESTROYER is offline
post #2 of 6 (permalink) Old 03-05-2013, 05:33 PM
gaspumpcity is offline
post #3 of 6 (permalink) Old 03-05-2013, 09:05 PM
Triplej's Avatar
Here is the brand I have and for $14.99 they are a bargain. All their tools are USA made and well built.
http://www.mbsmfg.com/prdrloto.htm
Triplej is offline
post #4 of 6 (permalink) Old 03-06-2013, 12:50 AM
rageglide's Avatar
Toss a rag into the chain or get some 3/16th steel flat stock and cut it to length. Loosen it by turning nut in the correct direction helps a ton... Gentle steady pressure - won't be a problem. Trans nut is 70-80ft lbs, about the same as most car wheel lug nuts.
rageglide is offline
post #5 of 6 (permalink) Old 03-06-2013, 10:23 AM Thread Starter
those tools are great for loosening the clutch hub nut, but putting it back on I believe the basket will spin. Chuck from dragos took the time to call me and suggested putting in a clutch plate. He also answered many other questions. Knows his sh*t. sent me pics of pro chargers theyve done. If anyones lookin to make power or need service in the Illinois area I would look them up . First class
post #6 of 6 (permalink) Old 03-06-2013, 12:15 PM
rageglide's Avatar
Funny. I typically keep the clutch pack together as a unit so I assumed you were just removing the whole asssemby. With an empty clutch shell, a helper standing on the brake would be my preferred method. If nobody was around I'd probably put in a few clutch plates to spread the load.
J&M Blu Hub Dongle versus the Sena Freewire againstdatide Audio 0 02-23-2017 01:23 PM
What covers hub spaces on HD wheels ? fat boy ultra Wheels and Tires 6 06-27-2013 11:09 PM
The Hub Traviskp Road Trip Discussions/Stories/Pictures 2 10-18-2011 10:43 PM
bolts in rear hub Sancho *General Road Glide Discussions/Pictures 3 01-12-2011 06:50 AM
