cracked cylinder? - Road Glide Forums
post #1 of 20 (permalink) Old 03-05-2013, 07:41 PM Thread Starter
cracked cylinder?
well i put the bike up on the lift tonight and started digging in to her because im getting ready to do some powder coating and paint plus some cams. when i noticed some oil residue on the cylinder. so i got a flash light and its inbetween two cooling fins on the front cyl right in the middle on the front side of that cyl. its completely dry everywhere. so im guessing that cyl must be cracked or somthing? i dont no! gonna call the dealer in the am to see what they say. still have 1 more year under warr.
jsdmax is offline
post #2 of 20 (permalink) Old 03-05-2013, 07:47 PM
71u140's Avatar
Cracked cyl?
Are you sure that's not the head gasket? Even if it is, it still shouldn't be leaking oil. Definitely something to have checked while it's still under warranty.
'13FLTRX103, Pro Stage IV kit, V&H slip-ons, 10" Chubby apes, EG Ultra Tour Pak, RG lowers, more to come!
71u140 is offline
post #3 of 20 (permalink) Old 03-05-2013, 08:20 PM Thread Starter
ya im sure! its just about center between headgasket and basegasket. right in the middle of friggin nowhere!
jsdmax is offline
post #4 of 20 (permalink) Old 03-06-2013, 12:34 AM
rageglide's Avatar
It's not a cracked cylinder...
The new steel multi-layer head gaskets don't use o-rings and can weep. The drains from the heads go through a port in the gasket which is where the oil comes from. Usually the weep is caused by starting the engine and rappin it hard when it's cold. If you like to start the bike and rap it for your bro's when you've got a beer in your hand, I'd put my money on this... :-)
That said, a pulled stud will cause the head gasket to leak which also could cause oil weep. That sounds like a quick chirp when you crack the throttle when cold.
rageglide is offline
post #5 of 20 (permalink) Old 03-06-2013, 06:33 AM Thread Starter
ill try to get a pic of it today. wouldnt there be a sign of oil near the head gasket tho? its perfectly clean from the headgasket down about 2-3 inches then inside two fins theres oil on top and bottom of the fins.
jsdmax is offline
post #6 of 20 (permalink) Old 03-06-2013, 06:54 AM
We have not witnessed this as of yet, but this is not the first time we have heard of a late model bike, with a cylinder fracture issue.
Scott
Hillsidecycle.com is offline
post #7 of 20 (permalink) Old 03-06-2013, 07:59 AM
prodrag1320
Guest
Posts: n/a
im sure its not cracked,but it could be porosity in the casting.either way,not a good thing
post #8 of 20 (permalink) Old 03-06-2013, 08:19 AM
4getNo1's Avatar
I'm thinking the same thing. If there's a crack all the way into the cylinder bore itself then I would expect the symptoms to include way more than some minor oil leakage, especially during the power stroke.
No matter what though, I'm sure glad it's under warranty because I do bet that disassembly is necessary, maybe even to simply find out exactly what it is that's wrong. I hope 71u140 and rageglide have it nailed - that would be a relatively easy fix.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #9 of 20 (permalink) Old 03-06-2013, 12:33 PM
rageglide's Avatar
ill try to get a pic of it today. wouldnt there be a sign of oil near the head gasket tho? its perfectly clean from the headgasket down about 4-6 inches then inside two fins theres oil on top and bottom of the fins.
Shit, I gotta stop posting after a couple cocktails. I keep assuming... I assumed you were talking about the two fins at the head gasket.
Fractured cylinder seems like it would have more symptoms than a residue, such as an actual oil leak. Kirby's comment about porosity seems possible.
post #10 of 20 (permalink) Old 03-06-2013, 12:44 PM
4getNo1's Avatar
Shit squared. I read what y'all said instead of what OP said too and liked what I saw in your posts - didn't think it through. I still hope the oil is dribbling down from up a bit further though
4getNo1 is offline
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 03:46 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 01:07 PM
Windshield is cracked!!! MYFLTRX *General Road Glide Discussions/Pictures 5 09-04-2011 09:02 AM
Cracked Fuel Filter Hsg Phil_FLTRX ECM/Fuel Management systems 5 08-21-2011 08:59 AM
Headlight Assembly Cracked ironmark *General Road Glide Discussions/Pictures 11 12-18-2010 03:58 PM
