What to do? Re Cams - Road Glide Forums
post #1 of 13 (permalink) Old 03-05-2013, 09:14 PM Thread Starter
parker420's Avatar
What to do? Re Cams
Just bought a 2013 RG Custom...... I was going with the SE255, along with heavy breather, V&H Power duals w/ High output Slip ons...... My friend (HD master mech) says 90+ TQ and maybe 80 HP...... I want closer to 100 HP.....what to do???
parker420 is offline
post #2 of 13 (permalink) Old 03-05-2013, 09:21 PM
NorCal's Avatar
with my 2013 RG Custom I went with Cycle Rama 575 cams, HD Heavy Breather, Dragula pipe and TTS and I dynoed at 97.53hp and 113.65Tq
NorCal is offline
post #3 of 13 (permalink) Old 03-05-2013, 09:26 PM
X In Black's Avatar
Woods TW-222's. As soon as I get the money for them and pushrods, that's the way I'm going. 95.40/112.95. See the dyno chart on FuelMoto site HERE
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #4 of 13 (permalink) Old 03-05-2013, 09:32 PM
tsmartt's Avatar
What to do? Re Cams
Talk to Frank at Drago (site sponsor) about his setup. TMax tuner, Dragula 2:1 exhaust, max flow breather, TMan 555TQ cams. Search this site to find dyno charts for 95+ HP, 100+ torque with this combo. Doing cams to finish build when I get back from Daytona. Good luck.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #5 of 13 (permalink) Old 03-05-2013, 09:34 PM
pat123's Avatar
I had a set of 222's in my street glide for a bit. They pulled hard but fell fast. I felt like it hit a brick wall @3800 rpm. I didn't like it. I swapped them out for a set of 555's and was in love. I pulled them out of my street glide before I traded it in this past weekend. I haven't decided if I'm going to put them in my road glide. I might try something else. I really liked the bottom end torque of the 222's but I like the mid/high range of the 555's. I guess it I could find a cam with both.
pat123 is offline
post #6 of 13 (permalink) Old 03-05-2013, 09:59 PM
X In Black's Avatar
May have to check on the 555's. Good with stock heads/pistons?
2012 FLTRX
post #7 of 13 (permalink) Old 03-05-2013, 10:03 PM
pat123's Avatar
I swapped out the stock head gaskets for a set of .030 headgaskets on my street glide but on my road glide I'm not going to swap the headgaskets unless I put a set of ported heads on
To answer your questions stock heads and pistons will work perfect.
pat123 is offline
post #8 of 13 (permalink) Old 03-05-2013, 10:37 PM
PanWhenUCan's Avatar
Check out woods tw6g great all around cam kind of like the old andrews ev27 in the evolution motor also you may want to look at the 204 hd cams it also is a very good performer, My mech will pull out the hd255 and replace them with the hd204 cams I had 204 in 3 of my previous bike and think they work extreemly well if your not going for an all out build
PanWhenUCan is offline
post #9 of 13 (permalink) Old 03-05-2013, 10:44 PM
rageglide's Avatar
All cams come with a trade off. How big the trade off is depends on the supporting factors. Supporting factors are compression, intake/exhaust combos AND riding style.
An early close like the 222's and 255's gives you a big boost with stock compression but it's going to stop breathing earlier than a late close cam. The drop off at higher RPM is still going to be higher than stock. If you think winding it out means hitting 4500-5k RPM, you will probably be quite happy with an early intake close cam.
rageglide is offline
post #10 of 13 (permalink) Old 03-05-2013, 10:56 PM Thread Starter
parker420's Avatar
Well....i'm very green on the subject.....I blow the money on my toys, and normally go with the suggestion of my dealer. My 2010 SG had the 251 cam, and I cand remember what else.....they put the SE heads on, and I had the crappy manual compresion release buttons. I was getting close to 100 & 100....strong bottom.
I'm assuming my dealer wont order woods? If theres a way, I'm looking for about the same numbers or better, but without head work, or compression release things......I'm guessing i'm dreaming? I would like stronger mid this time....I think....lol.....Heck, told ya I was green. What about the 555's? But is there a lot more work involved?
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
If you're running an amp, what did you do for an antenna? anonymous_1 Audio 17 08-31-2016 02:11 PM
Do I have to re-tune after de-catt? BlueGlide12 Intake and Exhaust 6 06-08-2014 03:42 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
Which cams do you recommend? RoadGlide0611 Intake and Exhaust 21 10-23-2010 10:25 PM
