HP Torq RPM formula - Road Glide Forums
post #1 of 3 (permalink) Old 03-13-2013, 01:13 AM Thread Starter
kenrena1's Avatar
HP Torq RPM formula
Noticed post compairing equipment and HP or Torque variences. Im an old Diesel tech that has used this formula for years .
HP= torq x rpm / 5252
Torq = hp x 5252 / rpm
RPM = hp x 5252 / Torq.
If you know any 2 varables you can calculate the third.
I have seen post where torq was stated as the same for 2 different dyno runs but the HP changed. This is likely the result of RPM point being diffrent .
Meaning that either torq or rpm measurement point must differ, else the hp should be the same.
Thought this might help when comparing components & HP claims. Torque and RPM mathimatically equate to Horsepower.
just my $ .02
....................... My girls ......................................
kenrena1 is offline
post #2 of 3 (permalink) Old 03-13-2013, 07:26 AM
Good info!!
On occasions, I use this:
The angle of the dangle x the motion of the ocean = the torque of the pork.
Scott
Hillsidecycle.com is offline
post #3 of 3 (permalink) Old 03-13-2013, 09:10 AM
prodrag1320
Guest
Posts: n/a
just my $ .02
your math is correct,when we still had our dyno,we messed with it a bit.the results were closebut not right on
PPG Paint color formula numbers RoadHawg Paint & Bodywork Section 148 06-12-2018 11:37 AM
5sp HP vs 6sp HP sj01fltri Engine Related 11 12-29-2013 08:42 PM
Torq spec on exhaust head pipe bolts Dmize Intake and Exhaust 4 02-24-2013 07:53 PM
My formula for engine power DOOFUS Engine Related 20 01-20-2013 01:40 PM
